Old 3rd November 2004, 09:49 AM   #1
fallow is offline fallow  Finland
Default BrianGT's Gainclone hisses. what to do?
I just finished my first gainclone, and found out that it hisses. hiss can be heard putting my ear right next to speaker, my test speakers are not very sensitive.
What can I do to reduse this hiss, can transforers cause this hiss?
could regulation off power supply help?
I measured the dc offset and it was quite small around 30mV.
I drive cainglone through pre amplifier, which is my own making, and it's output noise level is around 5 uV, couls this be the source of hiss?
what output level is enough to generate noise from speaker? off cource this depends on sensityvity of speaker, but let's say sensitivity is 89db/W.
Old 3rd November 2004, 09:51 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
The amp _has_ noise and you will hear it if you have your ears very close to the speakers.
If the gain is 30 the noise would be 2-8 uV times 30 = 240 uV worst case. If you don't have optimized the feedback resistor values the noise can get higher.
/Per-Anders (my first name) or P-A as my friends call me
Old 4th November 2004, 01:34 PM   #3
Ok,
thanks for replying.
Noticed that the source of main noise was my preamplifier.
if shorted the input of gainclone the noise was almoust diminished. but when driving through preamplifier the noise was increased to level which is irritating, now have to do something to get rid of that noise.
Or can the noise become from impedance mismatch?.
Old 4th November 2004, 03:20 PM   #4
peranders's Avatar
If you have an opamp based preamp it's rather easy the enhance the noise performance. Even the old good buddy NE5534 will make things quiet. Check for an opamp with less noise than 10-15 nV/Hz
Old 4th November 2004, 06:32 PM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Since you are using preamp, you might reduce the gain of your GC amp. You can do that by replacing feedback resistor with 20k value and using 1k insted of 680R for gain setting resistor. You might also add 22k input resistor (insted of 220R). This will reduce the hiss in your speakers.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 4th November 2004, 07:05 PM   #6
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
also, use good quality metal film resistors in all audio circuits.
Old 4th November 2004, 07:26 PM   #7
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Peter,
Is this a series or a parallel resistor? Generally, increasing the resistor INCREASES the noise. The (thermal) noise is determined by the equivalent input resistance, seen from the input towards the source, with the source replaced by a short. In other words, the equivalent resistance becomes the series resistance in parallel with the resistor to ground, if this last one is directly on the input. If it is on the sources side, it is effectively shorted by the source (low) output impedance.
Jan Didden
/Another new issue: Linear Audio Volume 3!
BrianGT gainclone kit newbie- help me shop! sansbury Chip Amps 14 19th June 2007 12:23 AM
Dual xfrmrs for Briangt gainclone ransom peek Chip Amps 0 26th November 2004 09:01 PM
FS: BrianGT gainclone kit. LM3875 Dual Mono Kit mattjk Swap Meet 3 16th November 2004 12:24 AM
BrianGT.com Gainclone kits Tuber Chip Amps 7 2nd September 2004 08:56 PM
Page generated in 0.10240 seconds (76.29% PHP - 23.71% MySQL) with 10 queries
