Old 2nd November 2004, 12:01 AM   #1
Default MOSFET output stage on Gainclone
Is this possible to do?
If I were to take a pair of MOSFETs or even a few pairs of MOSFETS, and use them on the output of a gainlcone amp, would it work? If so, would high power levels be achievable?
And, if this would work, would the sound quality be good, and, most importantly, how would it all connect?
Thanks to all,
Mike
Old 2nd November 2004, 12:11 AM   #2
Mr Evil is offline Mr Evil  United Kingdom
It is possible. I've done similar things before and it works quite well to improve output power. There are probably quite a few schematics floating around using both MOSFETs and BJTs.
Given that you won't need much current to drive MOSFETs compared to what a chip amp can supply, it is worth connecting a low-ish value resistor from the chip output to the load, forcing the chip to supply a certain amount of current by itself, reducing crossover distortion.
https://mrevil.asvachin.eu/
Old 2nd November 2004, 10:38 PM   #3
I searched but was unable to find a suitable schematic.
Any ideas?
And, if I build this, about how much output wattage and current would I be able to get with it? And what MOSFETS should I use?
Old 2nd November 2004, 11:21 PM   #4
You might try looking in some application notes from National or other manufacturers, and op-amp datasheets (since you can usually just substitute an op-amp for a power chip amp). You might not find anything specifically with MOSFETs, but most BJT based circuits can be adapted just by increasing the bias voltage to suit.
Mosfet Output Stage Capacitance Nelson Pass Pass Labs 17 25th May 2012 10:47 AM
Bipolar/MOSFET CFP output stage ashok Solid State 25 28th November 2010 09:31 AM
AMP with inverting output stage mosfet fab Solid State 112 28th January 2007 04:32 AM
single mosfet output stage ? AudioGeek Solid State 1 1st January 2007 02:31 AM
Mosfet output stage help (please) bob123 Class D 5 3rd January 2006 11:48 PM
Page generated in 0.07593 seconds (74.67% PHP - 25.33% MySQL) with 10 queries
