Old 31st October 2004, 02:06 PM   #1
rs1026 is offline rs1026  India
Default Few Gc questions from newbie
Hi I had few questions wrt lm3886 GC that I am building.
1.What is the minimum trace width allowed for power and gnd signals?
2.Will there be any problems if traces are small?
Please look at figure of the PCB that I have designed below.This is first PCB that I have designed so there may be lot of issues.I would be glad if someone can give me some pointers.
Old 31st October 2004, 03:04 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
There is no firm-fixed rule for trace width. You geberally want to have the high current traces (supply, ground, output) as fat as possible to reduce the resistance, but anything above a few mm can carry several amps continuous, more if only a peak once in a while (like music).
With inputs to differential amps, you would want to try to keep them apart (also the output to the +input) to avoid unwanted coupling which could give you instability.
Without having the parts placement, your layout looks pretty OK, especially if it is your first layout! I don't see any obvious problems, but if you ask for comments you should overlay a parts placement that people can refer to a schematic.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Newbie Sub Questions demondo Subwoofers 17 4th June 2007 11:13 AM
2 newbie DIY questions Alex Barnett Multi-Way 4 30th December 2006 02:41 PM
Newbie Questions Mjr7531 Multi-Way 8 20th December 2004 09:18 PM
more newbie questions feralear Tubes / Valves 2 3rd December 2003 05:30 AM
Newbie Questions BlakeB395 Tubes / Valves 1 20th June 2003 04:01 AM
Page generated in 0.06315 seconds (71.28% PHP - 28.72% MySQL) with 11 queries
