Old 30th October 2004, 11:32 AM   #1
Default radial capacitors???-info needed
hi
what are the pros and cons of radial capacitors, compared with the standard "axial"(is this correct?).
are the radial ones suitable for gainclones?
cause i found a place selling radial nichicon 50v 1000uf. it kinda looks like an oversize resistor.
tnx
Old 30th October 2004, 01:04 PM   #2
hacknet is offline hacknet  Singapore
i thought the standard were radial, and the oversized resistors were axial...?
Old 30th October 2004, 01:39 PM   #3
mcs is offline mcs  Denmark
Yes, hacknet is correct. You have the two types mixed up. Radial is the type where both leads come out of the same end. Axial are the "big resistor" ones.
Axial caps are not any better or worse than radial caps, so you can use any type. I used axial caps in my amp to keep the boards flat (see here: http://stiftsbogtrykkeriet.dk/~mcs/LM3875/).
Best regards,
Mikkel C. SImonsen
My personal electronics website
Remote control kits website
Old 30th October 2004, 04:43 PM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
One stands up (radial) and the other(axial) lies down. So it's really just a case of whether you want a flatter but larger layout or a tighter one that is taller.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 1st November 2004, 11:02 AM   #5
This thread is getting very sexy!
Old 1st November 2004, 01:04 PM   #6
Nuuk's Avatar
Right, stop right there Carlos! Franz G will be a long any minute to tell you off.
Old 1st November 2004, 01:16 PM   #7
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Here I am
One advantage of radial caps, is: they can be placed very nearby the chip, don't forget this!
Franz
Old 1st November 2004, 01:22 PM   #8
Nuuk's Avatar
Brazilians Franz! That's all they think about! (putting caps close to chips)
Old 1st November 2004, 01:29 PM   #9
Franz G's Avatar
Don't underestimate Swiss people!
Look my head: no more hair!
Do you know why?
Frontal, I loosed them, because I was too much thinking.
The backside is hairless, caused from a lot of sex.
The complete scalp is getting hairless, when you think just about sex the whole time!
Thats life!
Franz
Old 1st November 2004, 02:11 PM   #10
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Franz
From Radial caps to hairless backsides; now that's off topic
Just remember axial means 'through' the axis (centre)
A-40 info needed tuberider Pass Labs 6 10th February 2009 04:55 AM
Info needed on 1 sub 1 amp skooter Car Audio 3 27th July 2008 12:25 AM
Panasonic Radial vs Blackgate Radial Caps blindtiger Parts 1 11th March 2008 01:21 AM
Radial 5 Watt 0.47 Ohm NEEDED!!! Zero Cool Parts 4 25th February 2005 02:47 PM
resistors, capacitors, etc. NEED MORE INFO! sjay8179 Tubes / Valves 6 6th March 2004 01:04 PM
Page generated in 0.08496 seconds (82.25% PHP - 17.75% MySQL) with 10 queries
