Creating a differential signal from a single-ended signal for bridged amps Creating a differential signal from a single-ended signal for bridged amps - Page 2 - diyAudio
Old 30th October 2004, 01:50 AM   #11
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Creating a differential signal from a single-ended signal for bridged amps Send a message via AIM to Peter Daniel
Default Re: Re: Creating a differential signal from a single-ended signal for bridged amps
Originally posted by Pedja
For the adequate compensation and % of the $€£(...), I may offer you one such solution.
I think the solution here is not that challenging as I would have to hire a paid consultant.
But, I may be interested in discussing with you licensing your active I/V stage as I like it a lot. I'm also planning on developing my own version of parallel TDA1541 DAC and this circuit of yours fits there well.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th October 2004, 02:12 AM   #12
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally posted by Peter Daniel
I'm presently using S&B 102 TVC and as good as they are, there are certain limitations, like softening of highs in some systems/on certain material. Also dynamics are not always comparable to an active preamp. How would it be to combine transformer with an active line driver, like AD815 for instance (or discreet buffer)? I think there is even an example like that in application notes.
That approach has worked very well for me.
I posted this almost a year ago:
http://www.diyaudio.com/forums/showt...145#post264145
se
Old 30th October 2004, 02:20 AM   #13
Pedja is offline Pedja  Serbia
You have mail, Peter.
But hey... what with this differential signal?! I've just had the idea. Anyone else interested?
Pedja
Old 30th October 2004, 02:38 AM   #14
We surely are
www.audiosector.com
Old 30th October 2004, 12:17 PM   #15
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Absolutely true. Keep in mind fixed ratio transformers for some reason sound a lot better than the S&B. And are much cheaper.
I have used Lundahl LL1660 for phase-splitting or step-down duties and can assure you it sounds way better than the S&B.
For line input splitting Lundahl make a very tiny (AD815 size? ) and very cheap transformer - LL1544. I have a set and if you let me know the configuration (input buffer? max input voltage?) will gladly hook them up to a couple of your favourite opamps and let you know how it sounds.
Old 30th October 2004, 03:53 PM   #16
I would prefer no input bufers if possible. How about using it with AD815. I might order those Lundhals as well.
I have two pairs of LL1570, but I guess those are good for output only?
www.audiosector.com
Old 30th October 2004, 04:52 PM   #17
Steve Eddy's Avatar
Yeah. The thing about the TVCs is it's like having 24 or however many different transformers. A given transformer tends to work best with a specific source/load impedance. A TVC will typically see just one source/load impedance for all of its positions which means that most of its positions will have a less than optimum loading.
se
Old 30th October 2004, 05:19 PM   #18
carlosfm is offline carlosfm  Portugal
Banned
Not good for me, thanks.
Old 30th October 2004, 06:55 PM   #19
markp is offline markp  United States
Really good transformers are big dollar items and come with their own set of problems. The DVR134/5 does a nice job with little extra parts and you may find after all the work on a discrete circuit that it was a learning experience with the same results. You dual FET circuit is an option but who wants more caps in the signal path?
If it sounds good... it is good!
Old 31st October 2004, 06:46 AM   #20
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I'm considering here a simple circuit to add to the LM4780 board and convert it into bridged amp, as many people asked about it. Transformer, apart form the size restrictions, will not always fit in everybody's budget.
Originally posted by Steve Eddy
Quite so. Unless you go with one of the cheapie $10 jobs.
This one is fairly respectable... a couple Joes have compared it favorably with much higher priced transformers.
http://www.edcorusa.com/transformers...wsm10k-10k.htm
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Creating a differential signal from a single-ended signal for bridged ampsHide this!Advertise here!
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 06:18 AM
testing a single ended or differential topology Stefanoo Pass Labs 11 26th October 2007 05:59 PM
Converting from single ended parafeed to differential dsavitsk Tubes / Valves 9 12th July 2007 06:46 PM
Volume control + Single Ended -> Differential Amp koolscooby Solid State 2 5th April 2004 11:50 PM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 02:05 PM
Copyright ©1999-2017 diyAudio
