diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Creating a differential signal from a single-ended signal for bridged amps (http://www.diyaudio.com/forums/chip-amps/44106-creating-differential-signal-single-ended-signal-bridged-amps.html)
Peter Daniel 29th October 2004 05:15 PM
2 Attachment(s)
It seems like this subject became pretty popular recently.
The easiest way would be using DRV134, however, I was thinking about something more challenging and less usual.
Combining some schematics I've seen previously (basicaly Pass balanced GC and Borberly preamps), I came up with this. Would it work well in that application?
There is also a possibility of using regular op amps for conversion, and I will post some examples later.
Peter Daniel 29th October 2004 10:32 PM
2 Attachment(s)
Seems like the subject is challenging indeed, as I only received one comment so far (by e-mail), mixed advice though, and I'm not sure if I could even consider it, especially when it was trying to correct Mr. Borberly's choices. I'm sure more e-mails will come. ;)
In a meantime, we move to ICs, as they are always safer to play with. This is my vision of pretty good, op amp preamp. It is in fact based on an actual, very well sounding preamp design, so no funny e-mails this time please.
I guess, for bridging purposes, the circuit could be used without input buffer (gain stage), but if somebody plans to add volume control, the buffer may be actually preferred. I'm using here OPA627, and it sounds not bad. The phase splitting is done using OPA2604, and in this position they also sound fine, but Carlosfm suggested recently AD815 and I wouldn't mind trying those here, especially when they are described as balanced line drivers.
The two 1k resistors in series, between two op amps, were used like that on purpose and one can add another gain stage for truely balanced preamp operation at the point between them. There is also a switch allowing to change the gain setting.
carlosfm 29th October 2004 11:41 PM
Hi Peter,
You have a switch on the input buffer for 3x and 7x gain?
7x gain seams a little high...
As for the AD815, it seams to only be available in SMD version, and it needs a heatsink.
It's not so easy to use this chip, although... it pays.:D
Sonically I prefer the LM6172 or OPA2132 to the OPA2604.
Peter Daniel 30th October 2004 12:25 AM
Those values can be always played with, whatever preference. My preamp actualy is using those exact values and the gain isn't too high.
I also got some samples of SMD AD815 and I'm quite curious about its sound. After all we usually agree on sonic signatures of various chips.;)
So far I didn't replace OPA2604 yet, but might do it one day.
For gain setting it's probably advisable to be adding resistor in parallel with 1K (instead of switching resistors), so there woudn't be any switching noise.
carlosfm 30th October 2004 01:11 AM
Minimalist battery-powered preamp
2 Attachment(s)
This is a very good pre too.
Op-amp?
Just an LM6172.:D
Steve Eddy 30th October 2004 01:16 AM
Re: Creating a differential signal from a single-ended signal for bridged amps
Well, there's... the 'umble (and purely passive) transformer. :)
Or wouldn't that quite fit the "challenging and less usual" qualification?
se
Peter Daniel 30th October 2004 01:27 AM
I've heard good things about LM6172 so it is on my list of chips to try.
As to the transformer, well that is probably most elegant approach, yet not everybody wants to go with it.
I'm considering here a simple circuit to add to the LM4780 board and convert it into bridged amp, as many people asked about it. Transformer, apart form the size restrictions, will not always fit in everybody's budget.
Also, if somebody already has the balanced preamp, they don't really need anything extra and can drive two separate channels in a bridged mode, isn't it? This creates also another possibility; instead of adding a bridging board inside the amp, one might build a balanced output preamp and drive stereo amp in a bridged mode. I might go for that myself, actually.
Steve Eddy 30th October 2004 01:39 AM
Of course not. But you know I had to mention it. :)
Quite so. Unless you go with one of the cheapie $10 jobs.
Yup.
This creates also another possibility; instead of adding a bridging board inside the amp, one might build a balanced output preamp...
Using transformers? :D
Ok, ok. I'll put the pom-poms away now. :)
se
Pedja 30th October 2004 01:41 AM
For the adequate compensation and % of the $(...), I may offer you one such solution. :bigeyes:
Pedja ;)
Peter Daniel 30th October 2004 01:44 AM
I'm presently using S&B 102 TVC and as good as they are, there are certain limitations, like softening of highs in some systems/on certain material. Also dynamics are not always comparable to an active preamp. How would it be to combine transformer with an active line driver, like AD815 for instance (or discreet buffer)? I think there is even an example like that in application notes.
Copyright 1999-2017 diyAudio
