| Chip Amps Amplifiers based on integrated circuits |
#21 | |
![]() se |
#22 | |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#23 |
I used a mosfet ( VN66AFD ) based simple phase splitter for a few years before I went over to S&B102.
I'm currently upgrading it to see just how good I can get it to sound. If you are interested I will post a cct mike |
#24 |
Of course I'm interested.
#25 |
OK - here it is then...
Some of the values are approximate. The design features are VN66afd / 88afd sounded better than some other types very low noise power supply ( I noticed recently that alkaline sounds better that lead acid hence the dropper resistors to a BG I guess ) The voltages drops across the o/p stage are optimised to give constant power so hopefully least memory distortion. I guess the trimmer pot ( to set the bias ) could have another dropper resistor to the battery pos terminal and another decoupling cap. each channel should have seperate PSU more current and / or voltage is OK up to about 0.3W across mosfet of course it does not have to be batteries but TR & diodes would need extra filtering to get the noise down Which reminds me, did you ever come to a conclusion about snubber caps/resistor etc across the TR secondaries ? I still regard this as a miracle mod for anything that does not have it already. cheers mike |
#26 |
Of course, a valve phase splitter might sound nicer...
#27 | |
#28 | |
I was quite suprised that peter says that his TVC softens the treble sometimes. Peter - what preamp are you using that has clearer treble and better dynamics ? Most of the people that I know that use TVC regard it as the most transparent option available. mike |
#29 |
I'm using heavily modified ML380S.
On classical and jazz TVC is better: cleaner and more natural. On electronic music (house, industrial), active preamp seems like a better choice. The early versions of TVC, were definitely reducing highs; for instance in my friend's system with Alephs 2, he didn't like transformers at all, but they worked great with GC. The current version is better in that regard, and it's hard to say if such reducing occurs. They are definitely less colored than a ML preamp, yet they still have a sound of their own.
#30 | |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| testing a single ended or differential topology | Stefanoo | Pass Labs | 11 | 26th October 2007 06:59 PM |
| Converting from single ended parafeed to differential | dsavitsk | Tubes / Valves | 9 | 12th July 2007 07:46 PM |
| Volume control + Single Ended -> Differential Amp | koolscooby | Solid State | 2 | 6th April 2004 12:50 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.11086 seconds (81.69% PHP - 18.31% MySQL) with 11 queries |
