Old 28th October 2004, 01:57 PM   #1
JRKO's Avatar
Send a message via AIM to JRKO
Default Transformer & Heatsink
I dont understand the ratings too well but this falls within the specs for Brian GT's LM3875 kit
http://custom1.farnell.com/cpc/produ...ct%5Fid=275506
I cant find a definitive heatsink requirment...
Will this do?
http://www.conradheatsinks.com/produ..._350.html#MF15
the 75mm one has a thermal resistance on 0.72 C/Watt for 80C rise. They will only cost about £5.50 eachplus shipping.
Oh an internal wiring...as I only intend to make these once what is the ultimate? Silver, pure crystal copper, etc etc......?
'I have nothing. I owe much. The rest I leave to the poor.
- Francois Rabelais satirist & doctor d.1553
Old 28th October 2004, 02:18 PM   #2
JRKO's Avatar
Don't laugh too hard at the naff drawing.......
This is what I hope the units will look like when finished (her har har no not as bad as the drawing!!!)
The chasis will be made of wood (something real nice) as my metal working skills and the lake of good looking reasonably priced high WAF metal cases are far and few between.
The layout was inspired by conrad-johnson's Premier 350.
Power in one side and running through to the outputs with the heatsinking at one end...keeping all powe parts away from the source input/amp board.
The heatsink should screen the amp from the power supply but I may also layer the inside with copper leaf(?) to help.
Old 28th October 2004, 02:25 PM   #3
Idefixes's Avatar
Send a message via ICQ to Idefixes
CPU heatsink are quite good for this job.
they are a little bit over room temp. and my Gc is feeded with a 300Va 2x25V Tx.
Marc
Old 28th October 2004, 03:07 PM   #4
JRKO's Avatar
from those pictures the heatsinks I have specified may be too large....but I also need them that size for cosmetic reasons. Will that be a problem?
Is the wooden chassis ok? How do you ground it or is that not required? Is the copper leaf a good idea? What about internal wiring?
Old 28th October 2004, 03:37 PM   #5
sek is offline sek  Germany
No, of course not. A bigger heatsink never hurts...
Wood as an enclosure is okay! OTOH, the copper is a very good idea for shielding (isolating against induced noise). I would recommend it, but it will produce a little work to get the shielding 'tight'.
At first, you're not showing a primary fuse, nor a mains switch.
For wiring the mains jack, switch, fuse and transformer primary, I'd recommend a stripped and crimped wire that fulfills all the usual standards and regulations for mains wiring, e.g. a piece of good mains wire.
On the secondary side, I recommend using the same type of wire between transformer/rectifier, rectifier/amp and amp/speaker. I use quality speaker cable with a cross section of at least 2.5qmm, but 1.5qmm will also work. Which brand/type you choose is up to your taste.
Try to keep the double insulation on the primary side, e.g. leave the cable sleeve on, put shrink tube around contacts and connectors, etc.
Hope this helps,
Sebastian.
Old 28th October 2004, 03:50 PM   #6
JRKO's Avatar
Thanks for the reply sek.
I'll use the wiring thats on the transformer from the power socket to transormer and the attached secondary cables to the rectifier boards. Is it wise to always have a power switch? I may just power it up from the mains.
From there I'll need to make sure the cable can fit inside the front of the casinf to pass the heatsink.
Shouldn't the input wiring be fairly good quality cable?
The output will probably be come kimber 8tc as this is what I will probably be using to connect my loudspeakers.
As the amp and power sections are in different compartments and the heatsink is between the transformer and the amp I thought I would copper line the amp compartment only.
Old 28th October 2004, 05:58 PM   #7
Idefixes's Avatar
Here are all details about my Gainclone with wood case......
Marc
Old 28th October 2004, 06:47 PM   #8
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
You do not have to uuse a power switch bity it won't do any harm. You must use a fuse or circuit breaker on those primary connections though.
If you haven't done so yet, have a look at my GC FAQ pages.
(How many times have I typed that now? )
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 28th October 2004, 08:11 PM   #9
Send a message via MSN to officeboy
Maybe it should be your sig?
Old 28th October 2004, 09:05 PM   #10
Nuuk's Avatar
Now why didn't I think of that?
Utilizing a Standard Transformer as Heatsink? john65b Chip Amps 4 28th October 2006 02:35 PM
heatsink and other janey Pass Labs 5 13th January 2002 09:51 PM
Heatsink and Transformer Sale Thoth Swap Meet 0 4th September 2001 09:14 PM
Page generated in 0.11231 seconds (85.32% PHP - 14.68% MySQL) with 11 queries
