| Chip Amps Amplifiers based on integrated circuits |
Designed with input from BrianGT, here is a preliminary bridging board. There are two versions:
The first [upper] version, allows a jumper to be placed across the 2x6 pin header. This will allow either direct connection to the line driver chip, the use of a single op amp, or half of a dual op amp. Whichever op amp you choose, place it and the resistors, set the jumper, and it's ready to go. Both op amp chips are differential pairs, but if everyone wants single ended inputs, it's easy to change. The reason for wanting to use an op amp driver is two-fold: first, the DRV134 wants to be driven from a low impedance source and while this should be provided at the output of any source, the local op amp would guarantee this; second, the differential input allows single ended or balanced inputs for the bridged amplifer with a greater rejection ratio. The second [lower] version simply has the line driver chip. Keep in mind that this board requires a housekeeping supply of up to +/- 20V. Concerns already: fatter traces, especially for the power [they are 12mil right now] extend ground plane on op amp board similar to line driver only board connect other ground traces to ground plane [help please, i can't get the GND net to connect all the GND pins] Anyone have any other comments or concerns? Please discuss.
#2 |
Sounds cool!!!
It's better to have loved & lost than to never have had a good pair of speakers at all....... |
#3 |
I have eight sets of Brian’s LM4780 PCB’s on the way and was planning on using them in a paralleled / bridged fashion to yield ‘bout 200 watts per channel for an eight-channel HT project I have going. I already have the DRV134’s. These boards would save me the layout and procurement effort. I’d be in for eight of ‘em…
-Casey Walsh |
#4 | |
diyAudio Moderator Emeritus
Your boards shipped out to your monday morning, so you should receive them soon. The DRV134 thing should work great. I am going to start investigating solutions soon myself. It would be nice to add a simple bridging board to the next revision of the pcb set. -- Brian |
#5 |
Evan,your layout looks good.and do you have set up a regulator psu for the [lower] version?
here is my BLD design.wish it can helps. BLD driver for Brian,the BLD has already finished,I will send to you asap.hope it is helpful to your design. rgds digi |
#6 | |
-- Brian |
#7 |
Brian, I got OPA134s, not DRV134s!
I finished soldering the first kit today. Wonderful! I can't wait to get it finished so I can hear it. Thank you! Digi01, no, I didn't see anything in the datasheet that indicated I needed any regulating. I was planning on a Tx having a housekeeping secondary to power the op amps and DRV134. |
#8 |
Ok, here it is in all it's glory. I think everything is finished except for the trace width. I am of the mind that with the small amount of current the small traces are good. they reduce parasitic inductance. However, I am open to increasing them if that is what everyone wants.
The simple board: |
#9 |
And the advanced board:
#10 |
Isn't pin 1 and 2 supposed to connect? And 7 and 8?
But what do I know? the one I built with one of thse chips had an annoying, odd popping sound in the output
| Free halfer bridging board | woody | Swap Meet | 2 | 3rd April 2008 09:26 PM |
| Bridging Stereo Amps | 375 | Tubes / Valves | 9 | 12th August 2007 06:29 PM |
| Bridging board for 4780 | G.L. Tirebiter | Chip Amps | 1 | 14th December 2005 11:05 PM |
| bridging channels on stereo reciever | 9am53 | Solid State | 10 | 8th December 2005 03:16 PM |
| Bridging stk 4192 II chip | rs1026 | Chip Amps | 0 | 30th August 2004 01:41 PM |
| Page generated in 0.11318 seconds (72.42% PHP - 27.58% MySQL) with 11 queries |
