| Chip Amps Amplifiers based on integrated circuits |
#501 | |
Banned
#502 |
I just got a new trafo, 20-0-20 650VA.
This will give me 16,25A..... I was thinking to use the MUR860 as you, Carlos, use on you unregulated PSU. But, I am affraid that the MUR860 could burn Any advise ? Thanks.
If you want power you must add control |
#503 | |
Banned
You can also try the MSR1560. |
#504 |
I haven't done extensive load testing on it yet, but I used MUR1560's and they seem to be holding up fine on a 650VA, 50,000uf per rail snubbered PSU. I'll let you know hot hot they're getting once I start to push it.
Mike |
#505 |
Thanks Mike.
I will use the 650VA trafo in a PSU with ~70.000uF p/ rail. This will feed four LM3886 chips bridged, two for each channel. If you don't have problems, I think that I will not have
#506 |
This surely is the king of faq, but nevertheless I'd like to ask: Does the power rating of the 0R47 and 0R1 snubber resistors really need to be that high (2W and 1W, respectively)?
Estimating the dissipation in these resistors I arrive at values of the order of microwatts. Even with very generous assumptions for the values involved, shouldn't ratings of the order of 1/4 be plenty? I am asking because I am close to finishing the supply, but I have only access to wirewound resistors with high power rating. Since these (potentially) possess a high inductance, I'd prefer not to use them. Mick |
#507 | |
#508 |
Cmon. I'd really like to know
#509 |
the amount of energy stored by the capacitor (then dissipated by the resistor) is given by the equation:
P = C * F * (V^2) where V is the ripple voltage. |
#510 | |
| Page generated in 0.11963 seconds (75.77% PHP - 24.23% MySQL) with 11 queries |
