| Chip Amps Amplifiers based on integrated circuits |
I built the BrianGT LM3875 premium NIGC kit and think it sounds great; however, I have a turn-off thump. I built the units as true stand-alone monoblocks with individual 22-0-22 Avel 160VA toroids per side. I used a 0.1uF, 450v Auricap in the Cz position and a 2.7 ohm 5 watt Kiwame in Rz. I added a 56K Riken shunt on the input and a .22R Mills on the output ala Decimal Dungeon. Other than that, it is stock. I have no hum or buzz, just a thump when power is turned off. It is not particularly obnoxious, but I'd like to get rid of it. Any ideas?
#2 |
Power switched relays on the speaker outputs
#3 |
Properly implemented kit will not cause turn off/on thump.
It must be all those extras Seriously talking though, check your grounding, this usually creates that kind of problems. Power switched relays on the speaker outputs will help, but will not fix the problem.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
Does it happen if you leave the input (CD player etc) turned on? Does the same thing happen if the input is turned off first?
I had an amp which had both turn-on and turn-off thump unless the source was powered on first. I'm not sure what the real fix was, as I was fine with just turning the CDP on first and off last. Sandy. |
#5 |
Also, what's your DC offset at the output?
#6 |
I would take your extras out of circuit and test. I have done the same setup recently, (minus the zobel and extras) with 2 225VA transformers and it's dead quiet on startup.
All that is not given is lost. |
#7 | |
![]() But isn't this the ALWAYS recommended way of switching ANY chain of audio devices that don't ALL feature a turn-on/-off mute? I even learned to switch on the computer screen on last and off first, back in school! Sebastian.
#8 | |||
#9 |
40mV is fine, but maybe your source components pass DC as well so check with a source connected.
#10 | |
Do you have measurement equipment like an oscilloscope to verify what happens at turn off? I guess, not. Another approach: have you tested the GCs with the input devices disconnected? For further guessing, photos of the amp internals would be of great help... Sebastian. ![]() edit: Hehe, Peter was quicker, but pictures would still be great.
| 30V dc Turn On Thump Forte FT1 Amp | john65b | Solid State | 12 | 9th June 2011 02:04 AM |
| class d turn on thump | jol50 | Car Audio | 15 | 9th July 2009 08:31 AM |
| turn off thump | jayme | Tubes / Valves | 6 | 23rd September 2007 07:40 PM |
| Zen amp turn-on thump | robertpear | Pass Labs | 5 | 5th January 2001 12:23 AM |
| Zen amp turn-on thump. | vdi_nenna | Pass Labs | 2 | 22nd October 2000 07:27 PM |
| Page generated in 0.11481 seconds (77.94% PHP - 22.06% MySQL) with 10 queries |
