Old 24th October 2004, 02:34 PM   #1
Default Another LM4780 project
I designed this one a couple months ago when I had P-CAD at work. Unfortunately, I don't have that luxury anymore. I do have Cadence PSD 15 but no way to transfer the old design as I forgot to check on that before I left. Could anyone open this up and transfer it into a PDIF format for me?
The signal layout is nearly finished but the supply/ground routing needs a bit more work. And the power supply board was quickly thrown together as well.
It is designed as a stereo amp with a differential output and all the output filtering in NS's datasheets including a zoebel. The power supply board is attached to the amplifier board but meant to be separated if desired.
I have a hand drawn schematic that I can scan in when I get access to a scanner if anyone is interested.
Any and all questions, comments, and concerns are welcome
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
MY LM4780 Amp ziling Chip Amps 7 6th July 2007 05:46 PM
Lm4780 wotsascott Chip Amps 28 14th January 2007 08:59 PM
lm4780 karma Chip Amps 10 22nd November 2005 07:05 AM
I need advise for three channel Parallel LM4780 project. Padel Chip Amps 8 21st November 2005 11:27 PM
Page generated in 0.05557 seconds (74.63% PHP - 25.37% MySQL) with 11 queries
