| Chip Amps Amplifiers based on integrated circuits |
Hi ppl,
Built a GC using Brian's LM3875 kit, have checked + double checked my wiring but it still doesn't work. I think the problem is the trafo/rectifier, so i was wondering can i use batteries? I've built several headamps using 9/18v split supplies can i adapt one of these for testing purposes? These split supplies ie. +9v 0v -9 how would i connect them, Brians board has +V -V +PG -PG Any help would be appreciated as the GC has sat unfinished for a while btw i'm a newcomer so nothing technical guys. Thanks |
#2 |
You don't have a multi-meter? Start from your mains supply. Test everything - find out where you're losing power with the meter.
All that is not given is lost. |
#3 | |||
Brian gives detailed instructions on how to connect a +V 0 -V supply to the rectifier board in his PDF manual. In short: you would have to unsolder and repopulate your rectifier boards, that's why you don't want to try it. Also, a +-9V supply won't work, the LM3875 doesn't (safely) power up from such a low voltage. But you can try to use two separate split supplies on your kit. All you would have to do is let each of the two look like one transformer output winding. If you think of your split-supply's outputs in series, the are 18V supplies (between their respective +9V and -9V connectors). If you feel safe enough to try it, you can connect one supply with it's +9V to the kit's +V and with it's -9V to the kit's PG+. Then the second supply's +9V goes to PG- and it's -9V to the kit's -V. Please make a drawing of that to be sure. ![]() What trafo do you use? Can you probably post a photo from it's label and output wires? Also the way you tried to connect it to the rectifier board? Sebastian. |
#4 |
If you haven't done so already, try reading this ! And as stated above, check your PSU before connecting it to the map circuits to see that you have the correct rail voltages.
If you need help, draw out exactly how you have built your PSU and we may be able to spot the problem.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#5 |
Hi ppl,
Thanks for the posts. Left it alone for a couple of days, guess what -next time i look. i'd wired the trafo up wrong. Its now up+running sounds great too. Thanks to everyone for their help+ thanks to Brian&Peter for the kit! |
#6 | |
How does it sound?
#7 | |
Next project? |
#8 | |
| Amp non working | covik | Solid State | 0 | 12th November 2006 08:12 PM |
| WTB Krell KSA Mk2- working or non working | Jozua | Swap Meet | 0 | 20th March 2006 11:14 AM |
| sub amp not working | felzi | Chip Amps | 0 | 28th July 2005 05:29 AM |
| p3a not working, help! | benmanf | Solid State | 9 | 27th May 2005 01:02 PM |
| Page generated in 0.12013 seconds (71.96% PHP - 28.04% MySQL) with 10 queries |
