| Chip Amps Amplifiers based on integrated circuits |
#31 |
I assumed that he wanted > 100W into 8 Ohm, that's why I recommended the bridged version. We don't even know if he is going to use ±30V supply rails.
But, I don't event know if you are questioning my previous answer. |
#32 |
I think the parallel 3886 for a severe reactance 8ohm speaker is an excellent idea.
Each amp thinks it is driving a 16ohm load and thus produces less distortion. Each amp runs cooler and so triggers Spike protection less often. Each amp contributes to the current demand of the speaker which a single can never match. The downside is that a parallel setup probably does not work quite as well as a single, but I think this is outweighed by all the advantages. Ensure that each 3886 has +-10mF on it's power rails to get deep bass that when paired can control any 8ohm speaker. You could push the PSU voltage right upto maximum i.e. use a 28Vac transformer. To give slightly more headroom for transients.
regards Andrew T. |
#33 | |
Sorry for late, did not check this forum lately.... The PADS PCB file is at http://www.shine7.com/pa100_routing5a.zip Note that this is not a good layout, the drill holes are not big enough and the components are put too close together. I suggest you do some modifications.
My Audio Page |
#34 | |
#35 |
sorry for old post resuming,but I wanna ask mybe someone can convert this pcb layout to other extension layout(.lay or other) thanks
#36 |
Very nice work!
larryg |
#37 |
maybe there are other program that can open PADS .pcb files??
| LM3886 in parallel | Denis.BR | Chip Amps | 11 | 12th August 2009 07:16 PM |
| LM3886 parallel PCB's | jmillerdoc | Chip Amps | 0 | 27th May 2009 08:26 PM |
| LM3886 Parallel Use | Rachel | Chip Amps | 71 | 2nd July 2006 04:24 AM |
| *pics* parallel gainclone finished | rwaudio | Chip Amps | 10 | 3rd November 2004 10:59 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.10022 seconds (70.51% PHP - 29.49% MySQL) with 10 queries |
