Old 21st October 2004, 05:14 PM   #1
dezzz is offline dezzz  Denmark
Default Finished my GainClone
I just finished my GainClone, and I have a few questions to ask. I am using the Premium kit, and a 300VA toroid 2*20Volts. The sound sofar is magnificent, with a very good placement of the various instruments used. However...
I have more than enough power at my disposal, and so I was thinking that maybe I could lower the amplification, and achieve lower distortion figures, is this possible...?
My own speaker are driven perfectly(largest driver is a 7" Eton), I then took the amplifier to a friends house, and his much bigger speakers, 2*8" Vifa basses. The amplification is still adequate, but the kick in the bass is gone. Could this be improved on by implementing a larger Capacitor, maybe 3300 or 4700 instead of the Panasonic 1500. And what would the cons of this setup be...? Much slower bass?
Hope you can help me...
Old 22nd October 2004, 06:58 PM   #2
troystg is offline troystg  United States
troystg's Avatar
Hi dezzz-
Most likely his dual 8's are creating a 4 Ohm load. If you parallel the LMxxxx chips you would see that the snap and slam would mostlikely return.
Is your Eton 7" a 4 or 8 Ohm driver?
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 23rd October 2004, 04:05 AM   #3
alexw88 is offline alexw88  Hong Kong
Yes, adding more capacitors would help the bass a bit, but the mids and high won't be good anymore.
I am also running 4 ohm speakers, from my experience the following would help improve the bass (when driving 4 ohm speaker):
1. Run a higher voltage, 25V secondary seems good.
2. Regulate it, if you don't use regulator, when driven hard, supply voltage will sag for 1-2 volt. which would reduce the power.
3. Use LM3886, it can provide more current for 4 ohm load.
4. Parallel 2 3886s for even more power and current
I have done all of the above and I can say the bass of my amp is now very good.
My Audio Page
Old 23rd October 2004, 09:59 AM   #4
Thank you for your replies...
His two 8"s are originally 16 Ohm, but they are connected in parallel, so that is 8. And so is my Eton, thats why I thought they simply needed more power...
I might just try to add a regulator...
What about a valvebuffer, would that improve on the attack?
One more question, is it possible to wrap the toroid in a thick layer of aluminum foil, or something alike, to screen it of from the rest of the circuits, I am preparing a very small chassis for it, that is why this is of interrest...
Old 23rd October 2004, 04:15 PM   #5
You are running at 20V, after the rectifier it will be around 28V, if you regulate it, you may need a drop out of about 5V.
So after regulation it will be around 23V, which will give you less power. If you want to regulate, you need to start with a higher voltage.
My Audio Page
Finished my first Gainclone. Need some help. samsagaz Chip Amps 1 1st May 2008 05:04 AM
I finished my first Gainclone!!! lanchile07 Chip Amps 18 30th October 2007 01:47 AM
Semi finished gainclone LM3875 enzedone Chip Amps 7 4th October 2005 03:11 AM
Another finished Gainclone Treefingers Chip Amps 6 21st September 2005 09:32 PM
First Gainclone finished jarkaa Chip Amps 16 31st May 2004 05:29 PM
Page generated in 0.08755 seconds (76.86% PHP - 23.14% MySQL) with 10 queries
