| Chip Amps Amplifiers based on integrated circuits |
How do I cut a square out of aluminum?
I figure I can just use drill bits for circles. But I need to cut out a square for the ac input. Thanks, Matt |
#2 |
diyAudio Moderator Emeritus
Cut a round hole with a drill bit, then you can jigsaw, bandsaw, scrollsaw, hacksaw, or manually file it down. Surely not that difficult?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#3 | |
That what I was thinking. I didn't know if a special tool exist. Thanks, Matt |
#4 |
What tools do you have?
Drill a series of holes and shape the edges with a file.... You could drill the corners and connect them with a jeweler's saw, or a coping saw, or any reciprocating saw (like a jig saw) Clamp or screw a jig saw upside down to a board and it mades a decent table set up for very accurate cuts. Clamps, weights and sometimes padding work well to absorb vibrations. A pneumatic die-grinder works pretty well too.
onasis |
#5 |
If the aluminum is very thin, a square punch probably exists..
#6 |
Answer is somewhere in this thread ..... Useful tools and techniques
#7 |
Punches are indeed available, but they're not particularly cheap.
A 'nibbler' tool's a good investment (either a manual one, or the kind that fits a pistol drill). Good for all kinds of jobs like this! |
#8 | |
#9 |
Thanks for the input guys. I have four shipments coming. I have already received about 6 so far for this project. I’ve spent about $600 in tools and stock pills of parts. I should have everything done with the amp in about a week or so. My speaker won't be here till around 11/10.
Real dumb question: The switch I'm using for power has three terminals. Is one a ground? Do I use all three? |
#10 |
yes!
| wedge box vs square box | skooter | Car Audio | 4 | 25th September 2008 08:30 PM |
| Why are almost all sub boxes square | elambert | Subwoofers | 12 | 28th May 2005 08:49 PM |
| square wave in = square wave out | rick57 | Solid State | 19 | 15th April 2003 11:45 AM |
| Wanted non square aluminum extrusion (not for heatsinking) | rwagter | Everything Else | 2 | 29th January 2003 12:10 AM |
| Page generated in 0.09040 seconds (78.22% PHP - 21.78% MySQL) with 10 queries |
