Old 20th October 2004, 07:41 PM   #1
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Searching insulator type for LM4780 chip
We've been looking with Brian for convenient insulators to use with LM4780 chip package, but it seems like nothing ready made is available. Anybody got any experience with those?
So far it seems like getting bigger sheets from D-K and cutting them to size is the only reasonable way to go, but punching the holes might be a hassle.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th October 2004, 08:29 PM   #2
I am using fot it folie named Sarcon, typ 30U, dia 0.3 mm ( grey ), Rth = 0.26 °C/W. It is made as belt, so you must cut it yourself.
Old 20th October 2004, 09:20 PM   #3
Peter I was planning on usin TO3 insulator with a bit of trimming and a hole punch.
It totally covers but for the 2 holes af about 2 mm. for the 2 pins
of the TO3. This area is less than 1 % of total heat sink
Sheldon D
Old 20th October 2004, 09:25 PM   #4
To make few insulator for personal needs is not a problem, but I was getting ready for the kits and none of the above is really appealing.
Upupa's suggestion requires punching of the precision holes in the insulator material, and this is something I would prefer to avoid, (maybe not me that much, as Brian )
Sheldon's suggestion, while still workable, will not look professional with the kits supply.
www.audiosector.com
Old 20th October 2004, 09:32 PM   #5
TwoSpoons's Avatar
Have you contacted someone like Berquist? They were most helpful when I requested samples of their materials, and they do precut shapes.
Old 20th October 2004, 09:51 PM   #6
Banned
I used isolators for bigger chips (like STK).
I've cut one in half and it did for two 4780s.
But why bother?
I'm makin' another LM4780 amp and will just isolate the heatsink from the chassis.
This chip needs to be properly cooled down, it's two channels in a small package.
If possible, don't use isolators.
Old 20th October 2004, 10:03 PM   #7
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
How about asking National about this?
/U.
Old 20th October 2004, 10:13 PM   #8
TO 3 insulator is nonsens, guys . Much more better is insulated heatsink, as says Carlos, but for many guys it will be big construction problem. Peter, give to the kit stencil on paper - with scissors for nails isn't problem cut it yourself.
Old 20th October 2004, 10:22 PM   #9
We did contact them, but receive no answer yet. All in all, if nothing else is found, we will be cutting the pieces. We just thought that could be avoided by finding proper type of insulators, but it doesn't seem like it's been made.
It would be an option to isolate heatsink, but neverthereless, I thin an insulator should be included with a 4780 kit.
www.audiosector.com
Old 20th October 2004, 11:08 PM   #10
Banned
Cool Isolate the heatsink
Screw the heatsink to a piece of wood (MDF of whatever).
Screw the piece of wood to the chassis.
Done.
First chip amp finished - LM4780 bm0rg Chip Amps 14 29th August 2008 09:27 AM
Q&A - LM4780 type as bi-amped speaker driver FastEddy Chip Amps 5 28th August 2006 08:39 AM
Blew an LM4780 chip last night!How? Dominick22 Chip Amps 16 30th January 2006 03:54 AM
LM4780 Insulator in aussieland maf_au Chip Amps 4 31st July 2005 01:40 PM
It's time to solder my LM4780 chip G.L. Tirebiter Chip Amps 4 23rd March 2005 05:52 AM
Page generated in 0.11244 seconds (73.37% PHP - 26.63% MySQL) with 11 queries
