| Chip Amps Amplifiers based on integrated circuits |
I just got my tanny today from Plitron. I got everything I need besides the basic kit from Brain. He said his is going to ship it tomorrow. He was waiting to send it out because he got me some stuff from digikey. I can't wait to get together!!!!
I'm putting the 225va tranny in the gainclone chassis sold in this forum. The tranny has a diameter of 4.3". How close can I count the tranny to the walls of the chassis and the circuit boards? The plitron is drilled down the center. I have a mounting kit I got from Apex Jr that has a larger washer for the top. Can I just use a bolt and rubber footing? Does the large washer serve any purpose? Thanks, Matt |
#2 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
The plitrons I have do not need a large washer. the epoxy fill in the center is quite strong.
Your concern with bolting is to ensure that the bolt is not connected to the chassis at both ends. this makes a one turn transformetr winding
Sheldon D |
#4 |
diyAudio Moderator Emeritus
yup, potting is generally strong enough to forgo the top washer. I've also drilled a recess in the potting to flush mount the bolt head (and a second hole all the way through for the led winding.
I would keep the tranny as far as practically possible from the circuit boards. But then again some people experience no problems with very compact implementations as well.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#5 |
I can keep the tanny about 1.75" away from the amp boards. I'm unsure about the placement of the rectifier board. Should I place it closer to the tranny and away from the amp boards? Or close to the amp boards and away from the tranny? Or split the difference?
thanks, Matt |
| Now I know what this Tranny can do | Tarzan | Tubes / Valves | 3 | 8th January 2009 07:37 AM |
| Tranny Qs? | henkel | Parts | 4 | 12th September 2006 03:58 PM |
| what is the mounting depth and mounting diameter of this? | lemans23 | Multi-Way | 2 | 26th October 2005 10:52 PM |
| what should I do with this tranny??? | mylesmf | Tubes / Valves | 6 | 8th June 2005 11:42 PM |
| How to use LED with +- 25v tranny? | ransom peek | Chip Amps | 21 | 28th March 2005 11:55 PM |
| Page generated in 0.07655 seconds (74.20% PHP - 25.80% MySQL) with 10 queries |
