BALANCED LINE DRIVER,PCB layout share
Old 13th November 2004, 01:53 PM   #41
soundNERD is offline soundNERD  United States
one quick question.
Whats the Option part with the 300 ohm resistors?
Old 14th November 2004, 02:32 AM   #42
cjd is offline cjd  United States
Originally posted by Evilsizer
ok now got it. I would need three of these to parallel two sets of lm3886's and then bridge the two paralled.
thanks in advance
no... Paralleling two chip-amps requires resistors on the output leg (which isn't necessary on a single non-inverted amp), but no balanced input. Check the National Semi Application note 1192 for more info on paralleling amps.
Or you could pick up some of the BrianGT 4870 amp boards, which are paralleled already. (a 4870 is basically two 3886 on one chip, and his boards parallel them).
C
Old 14th November 2004, 03:29 AM   #43
Evilsizer is offline Evilsizer  United States
C
right now im tring to get the jist of things. Yes i do plan on getting brianGT 4870's. Im still working out what i want to use as for as GC's for a 2-way active speaker with active x-o.
"I Love To Camp!"
"Comensing Shock Therapy!"
Old 24th November 2004, 02:14 AM   #44
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
the BLD board part list:
DRV134/135 * 1
1uf50V * 4,(C1,C2,C5,C6)those caps that I have used is WIMA MKS2
47uf/35V * 2,(C3,C4)Elna RJH
LM7815,7915/78L15,79L15.the board can mounting to220 or to92L packaged regulator.
hook method below:
Old 24th November 2004, 03:10 AM   #45
DRV134/135 * 1
hook method below:
does imput voltage for the board have to be 18v or can it be higher or lower?
"I Love To Camp!"
Old 24th November 2004, 03:18 AM   #46
paulb is offline paulb  Canada
The regulators will need at least 18V to operate properly. You can go quite a bit higher, probably +/-30V. If you have less than +/- 18V you should probably build it without the regulators (bypass them instead).
Old 27th November 2004, 11:50 PM   #47
cdoggy81 is offline cdoggy81  United States
What is ment by the "hook method" ???
paulb, what would be the best way to bypass them?
IIRC they don't need much current? Battery powered be an option????......????
It's better to have loved & lost than to never have had a good pair of speakers at all.......
Old 29th November 2004, 12:16 AM   #48
digi01's Avatar
sorry for my poor english
it mean the method of signal connections and power connections.
Old 30th November 2004, 05:54 PM   #49
Coulomb is offline Coulomb  England
Coulomb's Avatar
I read the entire thread Digi, could not find the price of the BLD module.
Anthony
I like to stay current!
Old 30th November 2004, 06:06 PM   #50
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
personal quote from digi 22$us for 2 boards : O )shipped
going to order 2 on the weekend.
BALANCED LINE DRIVER,PCB layout shareHide this!Advertise here!
is DRV134 the best balanced line driver? anli Chip Amps 4 13th December 2004 05:55 PM
Balanced Line Driver Jerry Parker Everything Else 1 1st April 2003 05:32 PM
