BALANCED LINE DRIVER,PCB layout share - Page 4 - diyAudio
Old 12th November 2004, 06:18 PM   #31
cjd is offline cjd  United States
I assume (perhaps wrongly) this can also be used to connect to Pro gear that only accepts XLR inputs? This is an area in which I (perhaps very obviously) have just about no experience or knowledge.
Also, the optional resistors are for what? Or does that end up being the feed for the ground wire on an XLR...
It's always fun when I discover just how little I know and understand. More fun when folks are nice enough to answer.
C
Old 12th November 2004, 06:45 PM   #32
digi forgot to ask, how much did you pay for it (the chassis)?
even with all the searching of this forum i still cant find the answers to somestuff.
"I Love To Camp!"
"Comensing Shock Therapy!"
Old 12th November 2004, 08:46 PM   #33
markp is offline markp  United States
C
Frequently, cheaper 'pro' gear has xlr inputs that are not really balanced inputs but just use the 'hi' and ground. XLR is the pro standard as it should be a true balanced input to reject as much environmental noise as possible. And, yes you can use the circuit for pro gear with true balanced inputs.
If it sounds good... it is good!
Old 13th November 2004, 02:00 AM   #34
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by digi01
rabstg,
I am doing test now.I am interested in its drive performance and commonability.
If anyone is interested,it will be available asap
soldering,
Are these boards your design ? Can i buy some ?
Old 13th November 2004, 02:09 AM   #35
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
for Evilsizer,
the chassis is 150RMB($18USD).
for JasonL,
the board is available now.
group order threads here
here is the wiki page,ROUND 2
enjoys
Old 13th November 2004, 03:41 AM   #36
YAY! How did they work out with BrianGT's amps?
Havent found the answer to this so here it is. Would i also need to use one of these if i were to parallel your 3886 boards?
edit: went back and read on post on the other page about using it for paralled(or suggested use) but im still kinda confused. i thought you would only need it for a brigded amp not paralled as you are only increasing the current of the amp(s) to the drivers.
"I Love To Camp!"
Old 13th November 2004, 06:33 AM   #37
digi01's Avatar
the BLD is a unbalance to balance module,the purpose is used for connect two single amp in bridge.the two single amplifiers,can be an integrated stereo amplifier,it can be a pair of dual mono amplifiers too.
Because drv134 has certain output ability,it is beneficial to each half bridges of parallel connections.
I am still waiting for the PCB parcel of BrianGT's to arrived, it is still on the way.
digi
Old 13th November 2004, 07:39 AM   #38
ok now got it. I would need three of these to parallel two sets of lm3886's and then bridge the two paralled.
thanks in advance
"I Love To Camp!"
Old 13th November 2004, 10:18 AM   #39
What schematics are you using for it? Did you already try it on an actual bridge with your 3886 modules?
Carlos
Old 13th November 2004, 12:29 PM   #40
digi01's Avatar
this is the sch file:
http://www.diyaudio.com/forums/showt...571#post494571
I have work on it for my 3886igc in skeleton building.its fine
Now,I am setting up all parts in the chassis.I think that clean and compact assembly can obtain better performance.
is DRV134 the best balanced line driver? anli Chip Amps 4 13th December 2004 05:55 PM
Balanced Line Driver Jerry Parker Everything Else 1 1st April 2003 05:32 PM
Copyright 1999-2017 diyAudio
