| Chip Amps Amplifiers based on integrated circuits |
#11 |
when I get the boards,it looks more sweet than my imagine.I will do some test with BrianGT's 3875nigc and 4780,myselfs 3886igc.
enjoys digi |
#12 |
digi01-
When will they be available for order?
Troy Thinking positive doesn't make things better, it makes you a better person. |
#13 |
rabstg,
I am doing test now.I am interested in its drive performance and commonability. If anyone is interested,it will be available asap ![]() soldering, |
#15 |
excuse my newby question, but what exactly is a balanced line driver?? Can i see it as a pre-amp?? or is it only to connect 2 mono amps (gainclones) to 1 speaker.
Can anyone explain it to me in newbylanguage? Thanks
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn. |
#16 |
Hey digi01-
Out of curiousity does the BLD have a gain > 1? Or is it EASILY adjustable? Either way I'm still in when they are ready...
#17 |
Hey wim-
Awaiting digi01's reply to my previous post before I answer your.. If it can be operated at "higher" gain than 1 you should be able to use it as the driver stage in a pre-amp.. Pre-amp to what device? Stereo, guitar, test equipment, etc.?
#18 |
Thanks for your reaction.
What i mean is: were do you use a balanced line driver for? What is it? What can you do with it? does it come in place of a pre-amp, or can you use it in combination with a pre-amp and a power amp? When i know what is is for, i want to use it for audio, for gainclones (i have build several, and they sound great). Sorry for my silly questions.
#19 |
Hi wim-
Well the purpose digi01 built it for is to build a bridged gainclone. This circuit (using the EXCELLENT drv135 chip) is taking a NON-inverting signal and splitting it evenly to send out a balanced + and - signal to drive the inputs of matching (hopefully paralleled) Gainclones. Therefore one gainclone amplifies the positive half of the signal, and the other Gainclone amplifies the negative half of the signal. When the two halves are combined the amplifier develops "roughly" twice the voltage swing and power output. If the gain of the drv135 can be raised above 1 then it could be used as the pre-amp in the front end of a controller or high gain amplifier.
#20 |
Thanks a lot Rabstq, thats the information i was waiting for!!
Now i know how to use this kind of stuff.
| is DRV134 the best balanced line driver? | anli | Chip Amps | 4 | 13th December 2004 06:55 PM |
| Balanced Line Driver | Jerry Parker | Everything Else | 1 | 1st April 2003 06:32 PM |
| Page generated in 0.12016 seconds (76.64% PHP - 23.36% MySQL) with 11 queries |
