| Chip Amps Amplifiers based on integrated circuits |
#141 | |
#142 |
for those interested in make bridge driver with universal opamps,i have a completed design last year.
here is the device photos,sch,bom: bridge preamp http://assemblycraft.com/bridge_preamp.html -Zang |
#143 | |
i guess your passive preamplifier (100k) without decoupling caps in the signal route. |
#144 | |
thanks |
#145 |
I thought I'd try the Jaycar KC5469 bridging kit just to see if it was any good.
It was extremely easy to build with all hole-through components widely spaced (too widely spaced, PCB is a bit big). It seems to work fine though. It comes with a LM833 opamp. Also, there is an option on the PCB for using the amps PSU to power it with 2 x 15v 1W zeners and 4x 1W resistors, that are a different value depending of the voltage of the amps PSU. One drawback is that it only has a mono input. I would like to use it to power a sub. So I need to sum a stereo pair and use some kind of low pass to filter it down to 200hz before the input. Is it possible to use a PLLXO type filter with this? col.
http://www.minirig.org.au |
#146 |
Hi col,nice try with the thread hijack there but a pretty commerce project is not where we're at right now
![]() juluska,you can drop me a mail for the service -- Zang |
#147 |
opps sorry digi01, no hijak intended! just similar issues....
Will your boards run on 15v? col.
#148 | |
here is the sch&bom: http://assemblycraft.com/0903img/bridge-v1.1.GIF all the best, Zang |
#149 |
I've just finished my first bridging adapter for the bpa300 following the digi01 schematic in a quad opamp. It works really good, see here the results.
http://ignatiusprojects.blogspot.com/ In the next board i will mount the regulated PSU and adapter in the same board. BPA300 amplifier sounds superb. Thanks to all.
#150 |
hello digi01, hope its not to late to post here.
I wonder (as i am very new to this) why does your pcb have a positive and a negative voltage regulator? All the circuits i have experimented with recently have just used a positive regulator. Will this drv134 chip only work with a + and - regulator connected to pins 5 and 6? thanks for any info : ) |
| is DRV134 the best balanced line driver? | anli | Chip Amps | 4 | 13th December 2004 06:55 PM |
| Balanced Line Driver | Jerry Parker | Everything Else | 1 | 1st April 2003 06:32 PM |
| Page generated in 0.12859 seconds (76.58% PHP - 23.42% MySQL) with 11 queries |
