| Chip Amps Amplifiers based on integrated circuits |
#121 |
Hello
I have some extra THAD 1646 chip which even measure better than the DRV-134 . You can look up the test on the net. You can use as a replacement one by one to replace the DRV-134 chip. The price for 1 chip $6.50 Greetings |
#122 | |
MFR P/N 1646P08-U Anthony
I like to stay current! |
#123 | |
http://sound.westhost.com/project87.htm |
#124 | |
No! That is almost the same as the equivalent schematic as the DRV134 and will converts single-ended, ground-referenced input to a floating differential output with +6dB gain (G = 2). Rod Elliotts schematic: ![]() DRV134 equivalent schematic: ![]() DRV134, SSM2142 and THAT1646 all converts single-ended, ground-referenced input to a floating differential output, witch is good when you have a balanced receiver in the other end. But to bridge two amplifiers you need a bridging adapter, such as Rod Elliotts project 14. |
#125 |
Hello
My mistake is THAT 1646 I have a couple of extra . I needed to order 20PC to get bit lower price ,I just need 2PC . I sold some of them but I still have 6or 8PC EXTRA . If someone search for these chip I have some . Greetings |
#126 |
Hi CJ900RR,
While the schematic published on that page produces a floating output, the boards which can be purchased for P87b do not - this can be seen in the schematic on the secure section of his website, which I unfortunately cannot publish here. |
#127 |
Hi Seekerr.
Sorry I didn't know that, thank you for making that clear ![]() I did read that he states that the boards for P87b can be used as a bridging adapter on the site for project 14, but I thought that people might misunderstood that the schematic on P87 is the same thing as P14. But anyhow, the PCB's for P87B can be used as a bridging adapter, if you use the schematic in figure 2 shown at P14, or if you have access to the secure section of the site
#128 |
Question.
If the preamp is already fit with balanced output, could you bridge two standard gainclones (briangt's LM3886) directly?? Gerard |
#129 |
hi seems i still cant email folks o sorry for adding to this thread but,
Gaborbela: Do you by any chance have any of the THAD1646 chips left for sale? If so please email me. many thanks Nick |
#130 | |
I'm building the bpa300 amplifier, but i have problems with drv134 noise, so i'm studying the possibility of bridging PA150 pcbs with ESP project 14. IT seems easy to do for me in a protoboard and point to point, but i have a doubt. Can i put a simple pot just before these circuit to avoid any preamplifier? What is the input impedance of this circuit? Thanks |
| is DRV134 the best balanced line driver? | anli | Chip Amps | 4 | 13th December 2004 05:55 PM |
| Balanced Line Driver | Jerry Parker | Everything Else | 1 | 1st April 2003 05:32 PM |
| Page generated in 0.15340 seconds (63.41% PHP - 36.59% MySQL) with 11 queries |
