BALANCED LINE DRIVER,PCB layout share
Old 5th September 2008, 08:32 PM   #111
MrMajestic is offline MrMajestic  Sweden
MrMajestic's Avatar
Im a dummie, I wired the input voltage terminals incorrectly and now I probably have two toasted regulators.
Old 2nd November 2008, 12:28 AM   #112
gaborbela is offline gaborbela  Canada
Hello Zang
Do I have to use for the balanced driver a regulated power supply or just any power supply will do the job.
I ask these because the balanced pre driver it uses +/-15V and you regulated power supp voltage min18V .
Do I miss something here?
Or the regulated power supply for the amplifier not for the pre balanced driver .
Please let me know .
Greetings
Old 11th November 2008, 12:51 AM   #113
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Hi Gabor,
You can use any power supply do the job,+/-18VDC to +/- 30VDC.
The driver board have include a couple of fixed regulator on the +/- rails(LM18L15,LM79L15).
Zang
Old 11th November 2008, 01:27 AM   #114
Thanks Zang
Greetings
Old 7th February 2009, 05:28 PM   #115
juluska is offline juluska  Ukraine
Default balanced line driver for BPA300
I'm preparing a BPA300 amplifiers ( http://www.shine7.com/audio/bpa300_2.htm) and i need a balanced line driver.
Can i buy a pair of these pcbs for dvr134? How?
What is the proper voltage and VA rating transformer?
And what about the rectifier bridge?
Are not necessary bigger filter capacitors before the regulation?
Old 7th February 2009, 05:43 PM   #116
MrMajestic's Avatar
Default Re: balanced line driver for BPA300
They are available at www.assemblycraft.com
The need +-18V DC or +-15 if you bypass the onboard regulators.
Old 13th February 2009, 02:41 AM   #117
samsagaz is offline samsagaz  Argentina
i cant find the datasheet the purpose of the optional Resistors :S
Can someone please tellme what is the purpose of these?
Old 13th February 2009, 10:14 AM   #118
CJ900RR is offline CJ900RR  Sweden
I know that several people uses this solution whit the DRV134 and similar circuits to bridge their amplifier, but I would not recommend it.
DRV134 datasheet
The DRV134 (and DRV135 in SO-8 package) converts single-ended, ground-referenced input to a floating differential output with +6dB gain (G = 2).
The BPA300 (and almost every other LM3xxx-based amplifiers) have a unbalanced, single-ended input. To bridge this amplifiers you need to convert one unbalanced signal to one unbalanced, non-inverted and one unbalanced, inverted signal. The signals need to be unbalanced, referenced to ground, and not a floating differential signal.
The DRV134 is not suitable for the job and there can be issues when using it for that. The job can easily been done with a dual OP-amp and some resistors instead.
Old 13th February 2009, 11:04 AM   #119
I'm a beginner, how can a do this easily. Is there any kit, pcb, schematic?
thanks
Old 13th February 2009, 11:39 AM   #120
See this website. Both schematic shown there works like a charm!
http://sound.westhost.com/project14.htm
BALANCED LINE DRIVER,PCB layout shareHide this!Advertise here!
is DRV134 the best balanced line driver? anli Chip Amps 4 13th December 2004 05:55 PM
Balanced Line Driver Jerry Parker Everything Else 1 1st April 2003 05:32 PM
