| Chip Amps Amplifiers based on integrated circuits |
Brian,
I am not neccessarily a noobie, but have had tons of problems getting a TBIGC done right. I think the tube section along with grounding for three transformers are giving me the biggest headaches. Have you thought of doing boards for a hybrid. I know I would be very interested? Thanks for any comments, Regards ...Lee |
#2 | |
diyAudio Moderator Emeritus
-- Brian |
#3 | |
Apart from making them moboblocks with separate tube stage and supply , I've been going crazy trying to solve the ground loop issues. It's possible that I'm missing the crucial simple solution because I'm looking too hard. The usual trouble shooting problem! It is'nt desperately bad but it burns me up to see power supply charging spikes on the supply. Not to mention the strange reaction from the amp when you tap the speaker cone ! Did you try that ? Cheers, Ashok.
AM |
#4 |
While most of VBIGC here are based on Joe Rasmussen idea, and since he incorporates that in his commercial product, I don't think it would be appropriate to come up with such a board.
However, there is another proposition for VBIGC from Kuei, and he posted it here: http://ampchipdiy.com/phpBB2/viewtopic.php?t=85 Now, that is something I wouldn't mind to try
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
I liked Joe's schematic due to the low voltages required for the 6922 tube. I will shoot him an email to see if he would mind.
#6 |
Hi Peter,
Better you simulate such a circuit before trying it out. Also use an electrical speaker equivalent instead of a fixed resistor. While the first loop is fine , the second one at the 1 ohm resistor will see a frequency dependant signal. So when the speaker impedance rises at HF it will have less fedback and thus have a rising HF response. As the speaker itself has been designed for a voltage source , it will cause a rise in the frequency response. It will also vary with speaker and crossover types. Pandoras box ? I tried the tube circuit with usual anode output , but could not hear any marked difference compared to a voltage follower. There may have been some difference , but it isn't too obvious. Cheers, Ashok. King 30 : --- be careful with the 6922 in a real world circuit and low voltages . I have had problems with Electro Harmonix 6922 at +/- 35 volts. The Sovtek 6DJ8 worked better . Additionally the tubes supposedly can work at higher current at low voltage. I couldn't get that to happen. They worked only at 1 mA . I was told they should work at at least 5 mA. So a practical test is required. Simulation also works at 5mA but not the real tube.
AM |
#7 | |
Account Disabled
Me too Boban |
#8 |
I don't know if it was 'beginners luck' but I have no hum problems with my VBIGC.
However, as good as it sounds, I have found a big improvement in using Pedja's Jfet buffer with an IGC. remember, Joe's design was a 'get you going' design that he kindly donated to the DIY crowd, and never intended to be the last word in Gainclones.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#9 | |
I first saw this idea (buffer+GC) here http://www.diyzone.net/diy/references/tube/ Regards, Milan |
| Brian's LM3875 REV C boards | homer09 | Chip Amps | 134 | 18th December 2009 07:16 PM |
| Aleph 5 with Brian GT boards. (help) | edoirt | Pass Labs | 11 | 31st July 2006 05:15 PM |
| Page generated in 0.10583 seconds (80.70% PHP - 19.30% MySQL) with 11 queries |
