Old 18th October 2004, 09:38 AM   #1
Send a message via MSN to Scribble
Question measuring voltage rails
Quick question on voltage rails here.
I have a 500VA transformer with 25v secondaries, two bridges made from MUR860 diodes as per Peter Daniels schematic.
When measuring the rails i get a bit over 37volts but can i distinguish via a multimeter which rail is negative and which rail is positive?
Yes i do know which rail is which but im curious. Any suggestions?
Thanks for your time,
Joel
Old 18th October 2004, 10:03 AM   #2
rpapps is offline rpapps  Antarctica
Hi Scribble
I'm assuming your multimeter is digital.
Measure each rail.
If you get a minus sign ahead of the voltage reading then your probes are the wrong way around. Change them over and you'll have the polarity. If you don't get a minus sign, then they are connected correctly and you have the polarity.
If your meter is analog, it will deflect backwards if connected wrongly. Same process.
Hope this is clear.
Cheers
Rob
Old 18th October 2004, 11:28 AM   #3
MWP is offline MWP  Australia
Thats a very confusing way to describe it Rob...
Try:
Leave your multimeter -ve (ground) probe connected to the center tap secondary of the transformer.
Then test the bridge outputs with the mulitmeters +ve probe.
If it shows as, being -37V, thats you -ve supply.
+ve supply will just show as "37V"
Old 18th October 2004, 01:41 PM   #4
MWP:
My transformer is a toroidal with twin secondaries so it has no center tap. What would i measure it from on this transformer?
Old 18th October 2004, 01:59 PM   #5
troystg is offline troystg  United States
troystg's Avatar
Hi Scribble-
Pls post Peter's schematic you based it from..
Then I can mention SPECFIC test points to place the positive and grd test leads.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 18th October 2004, 02:21 PM   #6
Unfortunatly i no longer have the schematic on the computer but i will scan the one i have on paper tomorrow when i can access the scanner and post it on here.
Old 19th October 2004, 07:12 AM   #7
Old 19th October 2004, 07:53 PM   #8
troystg's Avatar
Hi Scribble-
The negative side of the top BR should be ground, and the positive side is + voltage.
The bottom BR is the opposite. The plus side of the BR is grnd and the negative side is - voltage.
Get me a picture of the amp and I can circle to test lead placement positions and repost.
Troy
Old 20th October 2004, 12:03 AM   #9
Thanks rabstg that was exactly my problem!
All fixed and working now
Zen V1 Higher Voltage Rails? fligti91 Pass Labs 4 13th November 2008 04:00 AM
OTL 6c33c Ciufolli v8.2 low voltage rails danielrs Tubes / Valves 3 4th December 2005 03:13 PM
Highest DC Voltage Rails anyone has used on a 3886 PHilgeman Chip Amps 15 9th June 2004 04:46 AM
Imbalanced Voltage Rails on Gainclone Kofi Annan Solid State 2 2nd March 2004 03:13 PM
Rails of most amps will be three times the RMS output voltage minus thylantyr Solid State 1 5th February 2004 07:11 AM
Page generated in 0.09702 seconds (81.91% PHP - 18.09% MySQL) with 10 queries
