Old 17th October 2004, 01:30 AM   #1
troystg is offline troystg  United States
troystg's Avatar
Default Center-tapped to dual secondary modificaton tutorial
Hi All-
I just converted my transformer from center-tapped to dual secondary.
The pictures are attached one per post.
Please notice in this diagram I added a second xfmr also...
The concept is here:
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 17th October 2004, 01:33 AM   #2
troystg's Avatar
first picture.
Troy
Old 17th October 2004, 01:34 AM   #3
troystg's Avatar
2nd picture of xfmr open.
Troy
Old 17th October 2004, 01:35 AM   #4
troystg's Avatar
3rd pic of coil end matching.
Fluke set to measure resistance. Value in desplay is 1 Ohm. Different xfmrs will have different values.
At the end will be a picture of the WRONG ends showing "OL" (out of limit) on the volt/Ohm meter.
Troy
Old 17th October 2004, 01:36 AM   #5
troystg's Avatar
4th pic of pairing the coil leads.
Troy
Old 17th October 2004, 01:40 AM   #6
troystg's Avatar
And the center tapped lead un insulated about to be unsoldered.
And yes I did nmean to put this picture higher... Oh yell, I hope you weren't doing it and reading at the same time....
Troy
Old 17th October 2004, 01:42 AM   #7
troystg's Avatar
Final pic of the xfmr retaped..
Troy
Old 17th October 2004, 01:50 AM   #8
troystg's Avatar
Coil ends of different coils. No continuity. Try again. :-)
Troy
Old 17th October 2004, 11:30 AM   #9
Did it Himself
richie00boy's Avatar
So, basically you just cut the loop that forms the centre tap, check which wire goes with which winding, and add a wire to the new points?
Old 17th October 2004, 03:12 PM   #10
troystg's Avatar
Hey richie00boy-
"that be it!"
Troy
two seperate single secondary toroids = combined center tapped transformer?? gbolly Chip Amps 5 5th November 2008 04:56 PM
dual primary//dual secondary toroid larryg Chip Amps 22 6th September 2006 10:24 PM
center tap to dual secondary conversion neutron7 Parts 4 30th November 2005 10:08 AM
Dual center tap secondary scottw Power Supplies 0 18th September 2005 08:54 PM
Two Transfomers => Center Tapped? Myren Analogue Source 6 12th April 2004 03:22 AM
Page generated in 0.10380 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
