| Chip Amps Amplifiers based on integrated circuits |
I have a toroid. I have a chassis. The toroid fits inside, but only without the mounting plate. I do not want to alter the chassis. I do not want to use a different toroid.
Any suggestions on mounting without using the plate? An intriguing alternative I saw when searching was to use epoxy to fill the center of the toroid and then drill a hole through the set epoxy for the mounting bolt. In practice, I'm not certain how well this would work. |
#2 |
Banned
The plate is thin, doesn't it fit?
Cut the bolt at the right length, it could be made not to pass the plate's top. |
#3 | |
#4 |
Banned
With some holes in the bottom of the chassis you could use some plastic bracers (is this the right english word?) to secure the toroid.
#5 |
#6 | |
What sort of epoxy would I want to use, I wonder? I know about avoiding a shorted turn. Thanks, Jeff |
#7 | |
What ever you use, don't try that pour in a single step using just epoxy at room temperature. With 40 or 50 cubic cm in one shot, the epoxy will get VERY, VERY hot in a few minutes time. It would most likely exotherm ~ results will be smoke & foam. You might make it one pour if you were to 1) chill or freeze the toroid 2) mix a filler with the epoxy (~colloidal silica or micro balloons or sand) 3) refrigerate during cure. The point is that you most likely just can't pour it un one slug without doing something a little special. |
#8 |
This epoxy fill method what plitron uses.
You should not have to to fill all of the "hole in the doughnut" Epoxy does not bond to polyethylene so jam some stuff underneath and only partially fill the "doughnut hole" from the top and bottom. My 400VA plitron is about 2 inches thick and the fill is about one inch thick
Sheldon D |
#9 |
One other thing the toroid on getting warm will expand somewhat, 1 mm is not very much expansion space.
What will be the result on your chassis if it expands more than that?
Sheldon D |
#10 |
Hi-
I taped the hole on the bottom and while the torid was sitting flat filled it 3/4 of the way with rubber silicone caulk. After it dried (long time due to it being a short thick plug) I put a bolt through it and a washer nut combo squeezing down on the silicone. 1. The silicone was dried to the torid so it was secure. 2. Squeezing down on the silicone put additional pressure on the inside of the torid further increasing the hold. No metal inside the torid EXCEPT the bolt that was small in comparison to the core. Similar in concept to the picture above but elastic and a little more forgiving if the bolt is not centered perfectly. Good luck.
Troy Thinking positive doesn't make things better, it makes you a better person. |
| Toroid? | billbeau | Chip Amps | 3 | 4th November 2008 03:26 AM |
| Trade a 40V 400VA Toroid for 20V 300VA Toroid | john65b | Swap Meet | 7 | 10th October 2006 03:49 AM |
| Toroid @ PE | troystg | Chip Amps | 23 | 20th January 2005 06:50 PM |
| What amp for this toroid ?? | Ford_V6 | Solid State | 3 | 5th July 2003 10:53 PM |
| Page generated in 0.12577 seconds (78.28% PHP - 21.72% MySQL) with 10 queries |
