| Chip Amps Amplifiers based on integrated circuits |
Hi!
I've made 10 LM3875 GC and all of them have the same problems: 1- 250mV DC at output with load and 300mV DC without load. 2- When I turn off the power and after the caps discharge (10.000uF / rail) I have no 'bump' but a sweep at high frequencies (puiiiii). Only 5 of them are connected at the same time (AV amp). I've tryed one at each time, and the result is the same. Is this normal?? I have the attached config Regards Pedro Martins |
#2 |
The problem is with your 100k shunt resistor at the input. The maximum shunt resistance shouldn't be more than the value of feedback resistor, in that case 22k. The lower the value of shunt resistor, the less offset.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
Thanks PD.
I'll try that
#4 |
Banned
Hi Pedro!
Yes, use a 22K shunt resistor on the input, and also change the input cap for 2.2uf. Use drain resistors after the big PSU caps. When do you come to Lisbon, man? I've got some things to show you.
#5 |
Hi Carlos
![]() Tell me, the drain resistors are...?? I attach the thing I think it is. And Lisbon? I've been there last thursday with my wife, but with very hurry... I've told her that we will go meet you . And before Christmas |
#6 | |
Banned
1k resistors should do the job. |
#7 |
Following Ohm's Law, if I have 30 V and a 1 k resistor means:
I = 30 V / 1000 Ohm = 0.03 A = 30 mA P = 30 V * 0.03 A = 0.9W So, the resistor must be 1kOhm / 2W at least, right? |
#8 |
Banned
Yes, 2W is fine.
| LM3875 gainclone problem | cjv998 | Chip Amps | 25 | 16th August 2007 12:57 PM |
| LM3875 amp problem | sebtdi | Chip Amps | 6 | 12th July 2007 07:23 AM |
| lm3875 problem | jsteigs | Chip Amps | 20 | 28th November 2004 01:24 PM |
| Hum problem with LM3875 GC!! | w00t | Chip Amps | 26 | 19th October 2004 09:36 PM |
| LM3875 Problem | nitin | Chip Amps | 0 | 23rd September 2004 07:40 AM |
| Page generated in 0.10106 seconds (76.18% PHP - 23.82% MySQL) with 11 queries |
