Old 14th October 2004, 08:12 PM   #1
mattjk is offline mattjk  United States
Default Is this Transformer OK to use with BrianGT's dual mono kit?
http://www.partsexpress.com/pe/showd...number=122-640
AVEL Y236750 330VA 25V+25V TOROIDAL TRANSFORMER
Should I get something larger, or will I need a different type for a dual mono gainclone kit?
Thanks,
Matt
Old 14th October 2004, 08:25 PM   #2
I used one of these to power two channels. A pair of Y236503 160VA 22V+22V's might be better for dual mono.
Earlier during this kit's creation, there seemed to be a general consensus that <25V per secondary was ideal. At least that's the idea I got.
Old 14th October 2004, 10:14 PM   #3
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
25vac is fine for the secondary voltage. The 2x22vac 160va transformer would work fine for monoblocks as well. The 320va transformer is overkill for one channel, but allows the option for reconfiguration at a later time if you decide to bi-amp your speakers, instead of using single channel monoblocks. I have heard that bi-amping works great with these amps.
Brian
Old 16th October 2004, 07:35 PM   #4
Thanks guys!
Old 22nd October 2004, 12:00 PM   #5
yuri777 is offline yuri777  United States
I have a question
What toroids would you guys recommend i get, if i wanted to build a 4 channel amp using four of Brian's new 4780 pcbs to biamp a pair of 4Ohm 89db Maggie MQ2.7QRs?
BrianGT chipamp.com dual mono lm3886 amp valleyman Swap Meet 8 21st October 2008 11:43 AM
transformer for LM3886 dual mono kit gonzalez Chip Amps 16 11th October 2008 10:55 AM
KrellClone KSA100-MKII 1000VA toroidal transformer for dual mono GB stolbovoy Group Buys 33 16th June 2008 05:39 PM
LM3875 dual mono (Carlosfm/BrianGT) Kooka Chip Amps 2 30th November 2006 08:43 AM
FS: BrianGT gainclone kit. LM3875 Dual Mono Kit mattjk Swap Meet 3 16th November 2004 01:24 AM
Page generated in 0.09514 seconds (74.88% PHP - 25.12% MySQL) with 10 queries
