| Chip Amps Amplifiers based on integrated circuits |
Hi All-
I'm building my second GC based on BrianGT's boards and was curious if anyone has used these enclosures before? I now need to build the pwr supply and they sell a larger version of this case but I don't know if the "rails" on the bottom of the enclosures would line up. If anyone knows there input would be appreciated. Thank in advance, Troy |
#2 |
The case open:
The wires are actually on the bottom side of the case. You can just make out the 2 groves on the bottom and the single on on the top. I mounted the chips to the top grove and want to use the bottom grove to connect the pwr supply case to the amp case. Thanks again, Troy |
#3 |
Hello Troy,
Well there's a coincidence - I was searching for details of that exact same case yesterday! I'm trying to find a dimensioned drawing to see what size transformer I can squeeze in for my Gainclone. Do you know the manufacturer of this case? Sorry I can't be of more assistance. Regards, David. |
#4 |
In this enclosure you will " bake " this amp, 'cos Rth is too big, respectively thermal protector of LM's will be reagiert soon. Rather use " correct " heatsink.
#5 |
I used these cases in my GCs and they were great.
See my webpage and navigate to GC3 |
#6 |
To Rarkov : Look atentionaly, you are using twice longer profile
#7 |
Hi Upupa-
I am planning on adding more mass to this enclosure by mounting it on the pwr supply enclosure and putting heat sink grease between the two. Also, this is a desk amp to drive a pair of very close speakers. I doubt it will come out of idle much. Hey David- The enclosure was bought from Parts Express and I "THINK" made by Hammond. Thanks, Troy |
| Page generated in 0.08869 seconds (78.76% PHP - 21.24% MySQL) with 10 queries |
