Gainclone for an active subwoofer
Hi All,
I have built a Gainclone with LM1875s, and I am very pleased with its performance. Its sound is excellent and its power is far enough for me and my room.
The next step I want to take is try to get those 2 octaves which are too low for my speakers. I am planning to build an active sub. What I want is fast, clean bass, not big power. I like the gainclone idea very much, and I know (I've seen it on my oscilloscope) that my Gainclone is able to produce nice low frequency sounds. This gave the idea of building an active subwoofer with a (mono) gainclone. I tried to search through the forum for this, but didn't manage to find anything. Has anyone tried this? Should the LM1875 be able to handle this or should I try to get an LM3875 instead (they are not easy to get here)? Are there any possible problems just because it will drive a subwoofer? What special things should I take care of? Does anyone have some schemas showing how to connect the input signal of that amp? Is there any simple solution for the low-pass filter?
m127
LM3886 subwoofer amp
I am using a ParaPix subwoofer amp I picked up on eBay to power a Dayton 10'"DVC woofer in a sealed cabinet. This amp uses two LM3886 ICs which can supposedly be bridged though I haven't tried that. I got it sans xformer and hooked it up with a 24-0-24 initially followed by a 20-0-20 as the final choice. This amp was sold by Apex Jr. some time back and his site (http://www.apexjr.com/parapixinfo.html) has very thorough documentation including schematics.
I like it so much I'm now building my own using LM3886's.
Then you MIGHT be satisfied with just one chip.
If you haven´t got it already you should buy a LM3886 preferably due to bigger output current in comparison to LM3875.
You can of course also parallel 2-3 LM1875 to get about the same power.
Will it be an 4Ohm sub? 20W is the limit with one chip.
With an 8Ohm sub you get about 30W max.
I am powering my TL woofers with LM3875's but with the addition of 10,000 uF per rail. I am surprised at how well this works (-3 db at 22 Hz) although I will also try a bridged GC to see if that is any better.
Any info on the woofers? Haven´t found them on your webpage.
Guess they are 8Ohm if you thinking about bridging?
Cheers
I have a single lm3886 running my sub. it has more power than I can realistically use. because seriously. 40-50 watts of REAL power is pleanty for all but really big rooms.
sounds great. I use a tl084 for a simple line level crossover. again sounds great. simple to work with.
Hi, could you provide me some more info about that line level xover? Some schematics, PCB diagram etc?
I'm not very good in electronics, but I can follow instructions, can read diagrams, I know what parts doing, can solder and do PCB :)
AeoN
Scribble said:
Im interested to know if anyone else runs the LM3*** chips to power a sub?
I currently have a stereo LM3875 igc but no where near enough bass. So i need and active sub. Plus i have loads of these chip's :D
Here is the example I have using BrainGT's LM3875 kits
The Butcher
