Old 9th October 2004, 03:51 PM   #1
Exclamation stk4241v
hi guys,
I hope somebody has some experience with this component...I'd like to build an amplifier with the stk4241, but I have a +/-30V power supply and a 4ohms load...Is it possible?does it work?an how much power can it deliver?
thanx a lot...
max
Old 9th October 2004, 05:58 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
I'm afraid its made for higher supply voltage and 8 ohm load.
Can we help you with the datasheet ?
Homepage: http://katalog.elektroda.net/
/Hugo
Old 9th October 2004, 10:48 PM   #3
Morbid is offline Morbid  Israel
Morbid's Avatar
Send a message via ICQ to Morbid
i've built stk 4046XI on 27VOLT dual supply and it worked well...
see my other thread of resistor burn at 4ohm load
Old 9th October 2004, 11:29 PM   #4
Stuart Easson's Avatar
Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
Default output power...
Approximate power from a +-30v supply into resistive 4 ohms is easy...
Assuming 3 volts dropped in the PSU, across the output devices, emitter resistors etc the peak voltage swing is +-27, since power = v^2/resistance, peak power is approx. 180w, rms power is half peak power, ie 90w.
If you plan to really use this power, say for a gig, party, etc you will need a PSU capable of 5 amps per channel average for that output level, or the voltage will 'droop' further and less output will be available...thats 300va per channel...not a trivial amount...
Stuart
Old 9th October 2004, 11:52 PM   #5
Default more comments
The datasheet shows output power with rails down to +-25 volts, so you are getting close to the lower end of the scale, going too low will eventually screw up the bias and increase distortion etc...
At a minimum, (based on 120wRMS/8ohms) the device has a current capability of approx. +-5.5 amps, so at your supply voltage you shouldn't run into issues, but again you are close to the limit, probably shouldn't push your luck too far, ie +-35v rails with 4 ohm load might kill the thing...
Good luck
Stuart
Old 10th October 2004, 10:30 AM   #6
Question hmm...
morbid, u say that it works with +-27V...but with a 4ohms load or a 8ohms load?so, if it's with 4, it must work with30...I know that the datasheet doesn't say anything about the 4 ohms, but I think it won't be a problem(I hope..)
Better Ideas for an amplifier 100wrms with a single layer pcb?
thanx...
Old 10th October 2004, 10:34 AM   #7
Talking i forget...
and what about a pari of stk4044v?+-30V are ok for this, always at 4 ohms?
(If somebody has something better than the sanyo datasheet, I'll be very pleased to know where to find it!!)
Old 11th October 2004, 01:21 AM   #8
Default stk modules for 100w/4 ohms
I'd recommend checking out the 4040 series, I know of 2 examples yielding 100w/4 per module...I recently dismantled an old pyramid car amp, rated at 2x100w into 4 ohms per channel. Before cannabalizing it I checked it's max output and it *just* met it's specs with a hard 14.5v into the SMPS. The modules it used were 4040xi (fully complementary) with approx. +-36v rails. For years Velodyne used the 4040iv (quasi complementary) in their servo subs, and rated the output >100w, though I havent verified this number yet...
I have recently purchased more of the 4040xi, not sure if the other version is still available.
Good luck
Stuart
Old 11th October 2004, 09:31 AM   #9
filgor is offline filgor  Australia
Default +/- 30 volt rails
hi morpheus82,
To answer your email to me earlier..
From what I know both the 4241 and 4048XI should work OK with +/- 30 volts. In both cases the distortion may be slightly higher than if you used a higher voltage.
At +-30 volts heat dissipation and output current won't be a massive issue so besides a few extra watts you won't get much more out of a beefier single channel like an stk4048.
The 4241 has 2 channels capable of ~72 watts each into 4 ohm loads with +-30 Volts if regulated. The 4048xi has 1 channel capable of ~77W at the same voltage. This less than expected performance is due to STK's having ghastly clipping voltages at the high current outputs required of 4 ohm loads.
Remember also that these figures would be worse if the Power supply is not a feedback regulated Switched Mode Power Supply and far worse if you're not using a SMPS at all!
PS. STK's seem to have a reputation for being hazardous when it comes to oscillations so watch your gain, layout and grounding.
Old 11th October 2004, 11:58 AM   #10
Question why smps??
hey, I have 2 toroids rated 800VA double output 25V...secondary rated for 32A...custom made...It's a great unregulated power supply!!with 33000uF at the out...Why it won't work fine?
I need a PCB of the STK4241V amp.... Dj BASS AMP Solid State 1 26th August 2002 07:32 PM
Page generated in 0.12935 seconds (71.36% PHP - 28.64% MySQL) with 11 queries
