| Chip Amps Amplifiers based on integrated circuits |
What comments welcomed
I am using two LM4781 for total of 3x2 = 6 channels One will be for the sub and a preamp to drive the vu meters, lm 3915.
#2 |
I just "finished" a five channel amp.. It still needs a lot of case work and a proper power switch. Also Ill add another channel to power a sub eventually (5 channels are lm3875, the sub will be 2 lm3886)
Is 35W enough for your sub though? What size/voltage transformer do you have, and heatsinks? For mine I have a very low voltage (18.5V DC) so the chips barely need heatsinks at all. Its the transformers that get the warmest, I should add some air holes above it. Make sure you have a lot of wire around if your doing star ground, mine is a rats nest. |
#3 |
#4 |
#5 |
#6 |
Alright I got a bunch of LM4781s, LM3886s, LM3915s, LM1973s and LM1972s. Now I intend to make a 7.1 channels project, the total wattage may exceed 250watts, any comments?
#7 |
well if you can't see those layouts now you got eye problems :P
btw, whats all the digital gear down the bottom of the schematic ? |
#8 |
Didn't take the time to parse the whole schematic, but it appears you have implemented some sort of digital control. What kind of parameters can you control? I doubt there is an Atmel microcontroller, RS-232, IR remote, LCD display and a front panel push button interface just to assign attenuation.
#9 |
yeap, there will be digital controls for each channel, the LM 1973 and Lm1972 are the digital volume controls, but I am doing away with the irda remote control, RS232 but adding vumeter, front panel attentuation interface and LCD into the amp.
The circuit is based from microjean 6 channels, but this is for 7.1 channels, = 8 channels. But from where I lived, there is a hard time trying to make a PCB out of the schematic. |
#10 |
Hy there!
The board I designed is for my needs. I like programming the microcontrollers and audio makes no difference. The digital interface is designed for debugging purpuses. The final board (if will ever be final) doesn't need all those chips like 2 memory modules, rs232 interface etc. The schematic has been changed in the mean time, temperature sensor was added, fan control and some volume interface gagets (work in progress , http://microjean.go.ro ). Bye...for now! |
| Getting Both Channels out of my M-501 | Getsum | Solid State | 1 | 3rd February 2011 05:50 PM |
| 2 channels to 1 crosstalk | dreamtear | Parts | 1 | 19th January 2008 01:42 AM |
| how to control 6 channels using one pot | Tambourine Man | Chip Amps | 26 | 16th November 2007 05:07 PM |
| 2 channels to one (not bridged) | Dan2 | Solid State | 16 | 11th November 2007 01:52 PM |
| WTB: 6 Channels of amp | dunderchief | Swap Meet | 12 | 26th February 2005 02:17 PM |
| Page generated in 0.10751 seconds (80.44% PHP - 19.56% MySQL) with 10 queries |
