Old 28th December 2004, 04:45 AM   #51
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
non-inverted LM3886,I have mail you the project file(protel version#0.1).
the attached pic,including top layer and bottom layer review.
best wishes
digi
Old 28th December 2004, 03:01 PM   #52
troystg is offline troystg  United States
troystg's Avatar
Hi digi-
Very nice.
I will look them over this week in between work and then request the files for manufacture.
Thanks again and hope all is well,
Troy
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 30th December 2004, 05:34 PM   #53
troystg's Avatar
Hi All-
Has anyone got a minute to look over digi01's boards?
I looked over them and have not seen any obvious issues but then I don't claim to be an expert in this, just a hobbyist.
Any advice would be appreciated. I will be using multiples of these boards with regulated supplies.
Troy
Old 30th December 2004, 08:12 PM   #54
ingrast is offline ingrast  Uruguay
Originally posted by rabstg
Hi All-
Nothing really to be anoyed of.
In my taste the double sided PCB is not really necessary (I have built test amplifiers and measured better than -110 db rel. noise floor with a Creative Labs Audigy II USB module and SpectraLab), but if cost is no major concern, then it is OK, makes for a much better looking board.
The resistor behind the lower pin row may be a liability, if I were asked, should relocate it elsewhere.
Rodolfo
Old 30th December 2004, 11:26 PM   #55
digi01's Avatar
Rodolfo
do you mean that small cap,Cb? it is a option part,the footprint of pins is 100mil.
Old 31st December 2004, 11:22 AM   #56
I was reffering to "Rn" if I read right.
Anyway if it is soldered on the PCB side opposite to the chip there is no major problem either.
Rodolfo
Old 31st December 2004, 11:25 PM   #57
troystg's Avatar
Hi Rodolfo-
I think the name is R"m" for the mute resistor, and it can be placed on top or bottom.
I tend to put it on bottom.
Thank you very much for your comments. They confirm my speculation that digi01 did an outstanding job.
Anyone else? See anything that could be improved?
Troy
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 07:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 06:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 12:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.08599 seconds (75.95% PHP - 24.05% MySQL) with 11 queries
