| Chip Amps Amplifiers based on integrated circuits |
Folks:
I have just completed an integrated Gainclone amp based on BrianGT's boards (LM3875). The amp turned out beautifully (pictures to come), but the amp's gain is very low. At maximum volume, music is politely audible -- two people standing 10' apart in the room could speak quietly and hear every word while the amp ran full blast. I'm using the 330V Avel transformer sourced from PartsExpress, and am getting about 37.6 VDC (plus & minus) off of Brian's rectifier boards. The only things the incoming signal runs through are a Greyhill selector switch and a DACT 20k attenuator. The source is an old Proceed CD player and the speakers are Meadowlark Kestrels. Wires are all short (1 meter interconnects, 8' speaker cables). Can anyone help me diagnose the problem? I gotta get more gain out of this amp! Thanks, Scott |
#2 |
Banned
It sounds like you made a mistake with the resistors.
Check out if you used the right resistor on the right place on the board. First check: the resistor from signal input to ground. |
#3 |
Carlos:
On Brian's amp board, there are only three resistors -- two 22.0k ohm resistors and a 220 ohm resistor. I installed the 22.0k resistors at points R1 and R2, and the 220 resistor at R3. Was that wrong? Thanks, Scott |
#4 |
Carlos:
Whoops, sorry -- there are four resistors: the 22.0k resistors went in at R1 and R2, the 680 ohm resistor went in at R3, and the 220 ohm resistor was installed at Rf. Did I screw this up? Thanks, Scott |
#5 |
Yes, you did. Did you read the .pdf?
#6 |
Hi SRMcGee,
R1 = 220 R2 = 20k R3 = 680 Rf = 20k Looks like you have R1 and Rf are reversed but please double check with schematics.These things have heaps of gain.
Greg Erskine |
#7 |
Banned
Check the instructions, I don't know the exact part ID, so it you post the schematic I can help.
Anyway, it really seams that you messed up with the resistors, as 220ohms for Rf is certainly not appropriate there.
#8 | |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#9 | |
By sheer coincidence, yesterday I assembled the BrianGT kit that I have here. Now, I am not really a complete newbie when it comes to building GC's! I've even made a couple of NIGC's before using P2P. But I dutifully got out the pdf help file and read it through from start to finish. It's very good (and I even get a mention in dispatches ) but...there is nothing that states clearly where each resistor should be soldered! Even I had to resort to the meter to check which solder pad was connected to what! May I humbly suggest that the pictures showing the resistors in place (step 7) could have labels showing the values of each resistor, or that the circuit diagram could have the resistor numbers added, or preferably both? This would improve an already excellent help guide!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#10 |
My reply sounded harsh and was not meant to be. The pdf does explain which values go where on page 5.
| Gainclone...No gain, YES pain. | JAZZ2250 | Chip Amps | 78 | 26th June 2010 12:30 PM |
| Help with GainClone gain setting | johan851 | Chip Amps | 35 | 15th February 2008 05:33 PM |
| The Gain in a GainClone? | Mmne | Chip Amps | 11 | 26th April 2006 11:40 AM |
| Gain Adjustment Advice Requested for Brian's PCBs | SRMcGee | Chip Amps | 4 | 10th October 2004 05:50 PM |
| Page generated in 0.13439 seconds (73.96% PHP - 26.04% MySQL) with 11 queries |
