| Chip Amps Amplifiers based on integrated circuits |
I've been following with great interest the trend towards using regulated PSU on our GCs. I have been trying to understand a technical reason why a regulated PSU is generally regarded as an improvement over a basic PSU. I can understand why a regulated PSU is an advantage for class A amps where a constant power and low ripple is advantageous, but the NS chipamps are class AB and have very high PSRR.
From reading many threads, the consensus is the NS chipamps don't like too much capacitance. Adding a regulated supply seems to allow the adding of significant amounts on capacitance without the drawbacks. With my limited knowledge, are the regulators really only acting as a buffer, hiding the caps from the chips? I know low power buffers are used on the signal input but are there high power buffers suitable for the power rails. Also has anyone tried a capacitor multiplier PSU on a GC? I was wondering if a capacitor multiplier has the right qualities to be an ideal PSU for a GC.
Greg Erskine |
#2 |
"generally regarded" -- not by me -- I've yet to see one iota of factual information to support this view in the case of the Overture series. this isn't to say that I would alter my view, but it hasn't been demonstrated. regulation will help an amplifier with poor PSRR, but this isn't the case with the Overture series.
all you do with regulation is burn watts that would otherwise produce SPL's. |
#3 |
hi jackinnj,
I agree with what you say, but there are quite a few accomplished GC builders here that prefer a regulated PSU. The traditional reasons for this don't apply so I'm wondering is there another reason. I haven't tried a regulated PSU myself because I'm a little hesitant to break away from original GC philosophy, short signal and feedback paths and minimal component count, but its getting to the point where I must try it for myself.
Greg Erskine |
#4 |
Banned
Let me put it this way: would you guys use a good signal op-amp (like an OPA627 or whatever) with an unregulated, low capacitance PSU?
This is even more serious, it's a power amp. Regarding regulated PSU with the Overture series chips from National, I could demonstrate the difference with only one CD track, you would be addicted. But you are far away, nothing much I can say. The proof of the puding is listening, at least for me. If you have big, very sensitive, easy to drive, horn speakers (preferably full-range or with simple crossovers), unregulated low capacitance will do. Unregulated high capacitance sounds bad with these chips. For real-world use, regulate. |
#5 |
I built a LM3886 amp quite some time ago. I could detect (instrument or listening) no advantage one way or the other except that with the same transformer, the regulated version would clip a little sooner. You could see this on a 'scope but in actual listening I never became aware of it.
The amswer to your question may differ according to the choice of amp-IC. If the app notes say anything about it, I would go with them a the most likely alternative. I think there is a "coolness" factor with regard to regulated supplies. Nothing wrong with that, of course. The logical course for you to follow would be to try both kinds of power supplies and decide for yourself. In fact I can't think of any reason why out can't build a single PS and just have regulated and unregulated terminal blocks so you could change over from one to the other with minimal effort. |
#6 | ||
Banned
With the same trafo you were regulating to a lower voltage. Quote:
#7 | |
#8 | |
FWIW, my LM3886 amp use 2x4700uF per rail and I have detected no short comming. Keep in mind it is my practice to select amps (purchased or constructed) such that I'm unlikely to ever overtax them. |
#9 | ||
Hi sam9
I did do a test 18 months ago bwtween 1000uF and 10000uF and couldn't really detect a significant difference one way or the other. So I haven't used large caps on my GCs since. I must revisit this again, now I know a little bit more about what I am doing. No one have commented about using a capacitance multiplier. From what I can work out it gives you virtual capacitance which is what I think these chipamps like. Again, I must try it.
Greg Erskine |
#10 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
| Need Help with + _ 90-100 volt regulated power supplies | wrich22 | Power Supplies | 4 | 21st March 2008 10:46 PM |
| Regulated Power supplies | Ryder | Solid State | 44 | 21st April 2004 05:15 PM |
| FS: (2) 28 VDC 11 AMP regulated power supplies. | FEThead | Swap Meet | 1 | 2nd May 2002 04:18 PM |
| Regulated power supplies | Jason Hubbard | Solid State | 20 | 10th September 2001 08:33 PM |
| Page generated in 0.12127 seconds (82.07% PHP - 17.93% MySQL) with 11 queries |
