| Chip Amps Amplifiers based on integrated circuits |
Hi Folks,
I've been a member for a short time and have bugged you guys a few times recently. Thanks for anyones input in the past. Anyway, my ultimate goal is to build a 4 channel 'powerhouse' Pass amp but that task is a bit daunting considering I have never built an amp before. .. I have decided to go with a gainclone as a first electronics project to get my feet dirty. I am not new to electronics, just new to building amps. I am way more experienced with loudspeakers. I have two problems: I hate to keep things simple ...and I am cheap (or maybe my wife keeps me cheap!) Therefore I am using anything I have on hand to complete the job. My amp will incorporate a 'humpty' sort of. It will be a switching power supply at 56v capable of 15a robbed from a small surplused Lorain telecom power supply. The unit has virtually no ripple and will see extra filtering. It has a full 0-56v output so I will be splitting that w/ 2 caps and resistors. The power supply is behind the amp in the pic. It will be installed in a matching chassis to the amp. The amp will be a non inverted LM3875 4 channel p-p with a 2 way active crossover internally. The crossover is an Audio Control 2 way automotive unit which will be removed from its chassis and incorporated into the amp. It is a super quiet unit and will probably be a great 'buffer'. Most importantly I had it kicking around and it was doomed to collect dust forever unless I did something with it. The chassis' are made completely of 'junk' I had kicking around in my garage and my company truck. Sorry for the lengthly post. See pic. Whadya think? Marc |
#2 |
"fist' gainclone?
I mean FIRST gainclone! |
#3 |
from what I gather...you will be trying to split the 56V in to 2 post and neg rails?? I dun think it will be that easy...perhaps a GC with single rail supply will fit you more...or modify the SMPSU to give +/- voltages?
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#4 |
I have heard of splitting single supply to split supply. I have seen this done by running 2 caps in series (15000 uf in my case) across the + and - rails. Also paralleling a 1k or so resistor w/ each cap to 'lock down' the voltages.
I do have my doubts though: if there were an unbalanced draw, wouldn't the voltages get skewed? Would it throw the resistor ladder out of balance and cause lower voltage on the high draw rail? I think it will. Whadya you guys think... Is this a viable option? Thanks, Marc |
#5 |
exactly...the imbalance could throw the thingy off wack...which is why it should be better to obtain the slpilt supply anyother way...
#6 |
if you bridge the outputs, splitting the PSU rails that way wouldn't be much of a problem. the center "ground" would just be a reference point and there is no risk of uneven loading of the rails.......
#7 | |
but if you must, run a pair of diodes, one from K on the "+" rail, A on the ground, the other A on the "-" rail, K on the ground -- this will help. I have a half-dozen 48VDC Sorensen switchers made for the Telecom industry -- they are almost completely devoid of switching noise and ripple -- haven't run GC's with them yet., but will use the single supply option. |
#8 |
Thanks Guys,
I am convinced to go 'single supply'. That brings about more questions as I am just looking at it. I can see that the big disadvantage is having such large caps in series with the output to kill the DC. The speaks I am using I expect will never see (or want to see) below 60Hz or so. Can I get away with using a smaller cap? Are the output caps supposed to be so large so they will not interfere with bandwidth, or are there other reasons as well? I did plan already to use a series cap anyway on 2 of the channels as they will be direct coupled to my tweeters...so the single supply option doesn't change THAT much for me. I am buildg a small set of line arrays with 4.5" and .75 inchers run with this clone,....they will hand off to a sub run with a Adcom 555. My real question is in regards to the size of the output cap, I guess. Can I get away with tailoring it to the impedance and freq. response of the speakers, somewhat. Thanku Marc |
#9 |
Anyone?
The obvoius answer to me is 'yes' a smaller cap can be used..but I may be missing something... Also, anyone have any info on a single supply schematic other than the National datasheet? Marc |
#10 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| My DIY Pre amp switcher pops! | MuthaFunk | Parts | 5 | 6th May 2009 02:07 PM |
| Good source switcher | MotoMan_Yz400 | Pass Labs | 4 | 22nd February 2009 02:25 AM |
| Bypassing switcher | iUSERTLO72p | Car Audio | 4 | 22nd January 2008 12:12 PM |
| WTB: abx switcher | garlandstephens | Swap Meet | 8 | 2nd December 2006 09:41 PM |
| Anyone use an offline switcher PS for GC? | speaker | Chip Amps | 4 | 26th March 2004 01:02 PM |
| Page generated in 0.11302 seconds (78.97% PHP - 21.03% MySQL) with 11 queries |
