Old 27th September 2004, 08:42 AM   #1
rs1026 is offline rs1026  India
Default Power,loudness,sound quality
From reading various threads in this forum I came to know that one of the factors that affects ouput power of a amp is based on the rating of the transformer used. This is somewhat clear to me.
But there were few questions that was not very clear.
1>I could not differentiate between Power and loudness. Does more power mean more loud the amp will sound?? Or will more power mean the sound quality will increase.
2>I plan to build chip amps using lm3886 and lm4780. I dont need more jarring or loud music.But I want clear music with necessary punch from woofers/sub woofers. Basically the sound should be discernible to the ears.
Is it possible to achieve this objective from the above chip amps.
3>Can these chips be used for home theatre systems, to drive sub woofers ??
The room size that I want use these amps is not more than 15feetx15feet.
Thanks in advance for answering these questions!
Old 27th September 2004, 09:45 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
1 Volume out = electrical power * speaker efficiency. 30-50 watt out in normal speaker is pretty high.
2 They are pretty good
3 Yes, but a bit little maybe for a sub, especially if you use only one IC but if you use bridge and/or parallel connection it will work
/Per-Anders (my first name) or P-A as my friends call me
Old 29th September 2004, 04:35 AM   #3
thomas997's Avatar
Two LM3886 should be good for a standard subwoofer.
You might find the stereo chip easier to work with (LM4780 - 120W bridged).
"Loudness" can be set by the gain of the amplifier. While power is determined by the chip, voltage of supply, and load.
I guess loudness is limited by supply voltage as well, as the output cant exceed the +/- rails.
Maybe someone else can describe it better.
Old 29th September 2004, 09:45 PM   #4
lulu is offline lulu  Chile
lulu's Avatar
you might also want to try the opa548 or opa549
UcD HG power supply sound quality? ghemink Class D 6 4th August 2005 04:01 PM
Quality Control differences = variations in sound quality? KT Class D 0 14th November 2004 06:51 AM
Sound quality,which is best? Richard.C Chip Amps 10 23rd August 2004 07:58 AM
Can a power cord affect sound quality?? sully Parts 103 13th November 2003 02:23 PM
Page generated in 0.07671 seconds (72.98% PHP - 27.02% MySQL) with 10 queries
