| Chip Amps Amplifiers based on integrated circuits |
W00t W00t W00t
![]() Assembled my amp today ( Design from scratch (LM3886) ), basically p2p (PSU board is not done yet, dont have the main caps), everything laying on the table, only one amp board connected ![]() So far - idle output .3-.2mV, supply rails @ idle +/- 31.5V, everything is working (so far I powered the sub (4 ohm bandpass), it was easier ) the heatsink is hot, but not hot as in "cant hold my finger hot", but the heatsink is tiny (some 486 cpu sink I had laying around) at the moment, I scrapped a nice skived fin sink, it'll be OK on that one, I hope .At the moment sub is happily shaking the room, but with this sink I cant do it for long, cause it'll overheat and shutdown eventually, bass is good I dont hear any apparent distortion or lack of power, no 50hz hum whatsoever, even with 1k caps on rails, amp is stable because RF bypass resistor-cap is cold, but I'll pull out my oscilloscope to verify that for sure and any other problems. Cheers.
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots. |
#2 |
The bench setup
![]() The case is commin any moment now, as soon as I'll get second trafo and aliuminium sheets (yeah the protection/delay circiut will be needed too cuz amp thumps on power on and on power off). I'm still thinking which indicator I'll use the frosted blue or sxy green led or a cut out simbol of some kind.
#3 |
How efficient is the speaker?
I guess if the sub was 8ohm then 2 3886 chips might be needed. I have some blue LEDs that I will be using, but they can be annoying if they are too bright. |
#4 |
I drive the sub at the moment, I'll use this amp on my other speakers, I'll assemble another one with crossover and rumble filter, you can find my sub searching for it in loudspeaker by keywords VEC7OR and bandpass.
| JBl GTS600, amplifier wanted! Dead or Alive, Alive if it can be helped:) | Paradise_Ice | Swap Meet | 10 | 5th August 2010 09:47 PM |
| My new amp...is Alive!!! | SpeakerScott | Solid State | 5 | 31st January 2009 04:15 PM |
| Its Alive ! ! ! | Madmike2 | Multi-Way | 7 | 4th July 2005 09:20 PM |
| DAC alive | till | Digital Source | 88 | 25th May 2004 09:35 PM |
| My first Nos dac is alive! | setmenu | Digital Source | 23 | 23rd April 2004 01:59 PM |
| Page generated in 0.06272 seconds (82.95% PHP - 17.05% MySQL) with 11 queries |
