| Chip Amps Amplifiers based on integrated circuits |
hi guys,thread killer digi01 come back again
![]() ![]() ![]() This amp is an opamp + discrete design.The idea of the discrete output is from EATON amp. With slight modification, the amp uses AD823 opamp to drive a pair of matched B647/D667 audio grade transistors, running in AB mode. Input stage using ERO caps and dale resistors; Elna 220uF BP non-polar caps are used as output; PSU with Telecom. Grade Siemens Caps and FC; Alps potentiometer; Gold plated RCA jack, and pre-out ( can serve as dedicated preamp.the amp voltage gain setting in 11) as requested. in fact,the amp style can drive a wide range of headphones with different impedance.it certainly can drive HD650, it can even drive AKG K1000 with PSU upgrade. this is a europe diyer work: http://www.justchords.com/docs/eaton.htmlhe use the amp to drive K1000 headphone. enjoys |
#2 |
The project looks quite good: congratulations!
Just one question: why pick that particular headphone design? Personally I have an aversion to using large capacitors in the signal path, and this project uses a big one (4700uF). The Eton project seems to be based on Jung's headphone amp, but that project had no output cap. So why not try that same project? Sheldon Stokes proposed a variation of Jung's circuit at Headwize, that used an OPA2132 chip and MOSFET drivers and no output cap. In any case I am saying this but I don't see a large cap on your project that might be the output one. So what circuit are you using? Carlos |
#3 |
| Downscaling Zen v.9 for use as headamp | kenev | Pass Labs | 34 | 12th April 2010 01:06 PM |
| MC headamp with opa | PTSOUNDLAB | Analog Line Level | 1 | 11th January 2008 09:56 PM |
| Leach MC Headamp | tmblack | Analogue Source | 21 | 20th December 2005 12:23 AM |
| Pocket pre-amp & headamp | digi01 | Chip Amps | 11 | 10th October 2004 12:49 AM |
| another chip headamp | digi01 | Chip Amps | 6 | 23rd June 2004 03:18 AM |
| Page generated in 0.07737 seconds (72.06% PHP - 27.94% MySQL) with 10 queries |
