Old 25th September 2004, 11:14 AM   #11
Send a message via AIM to DigitalJunkie
I've used this circuit before with TL072/82's and it works nicely.
http://www.users.qwest.net/~ptaylor/Audio/xover-2.jpg
Old 25th September 2004, 02:43 PM   #12
jackinnj's Avatar
There are application notes on both the Analog Devices www.analog.com and Microchip Technologies www.microchip.com websites which specifically address tuneable filters using digital potentiometers -- if you don't want to program the digital pots you can use the Dallas Semiconductor devices which don't require programming.
Here's the link to the Microchip AN737:
http://ww1.microchip.com/downloads/e...tes/00737c.pdf
if you don't want to use a digital potentiometer you can use an inexpensive 8-bit ADC and a bunch of relays to switch values of resistors, proportioned to the transfer function.
One other thing about filters -- don't scrimp on the operational amplifiers -- they need high bandwidth to function properly.
With respect to the digital filters from Linear Tech and Maxim -- there are some with very low noise, low THD. You have to carefully check the specs since some aren't designed for the audio bands.
Variable frequency active crossover FrankDIY Solid State 22 4th July 2009 04:30 PM
LM555 as variable frequency oscillator xyz9915 Everything Else 1 17th June 2009 01:10 PM
Variable High pass filter? ayearofholidays Instruments and Amps 1 30th April 2009 02:53 AM
low frequency, high pass filter memphissound Multi-Way 6 19th March 2007 10:11 AM
Variable center frequency filter metal Solid State 26 18th November 2005 09:12 AM
Page generated in 0.06748 seconds (73.28% PHP - 26.72% MySQL) with 11 queries
