| Chip Amps Amplifiers based on integrated circuits |
How do you measure the DC offset of a Gainclone?
Must i connect a source while measuring? If so, must the source be turned on or off? Must i pop up the volume of the Gainclone while measuring? Meter on DC milivolts, connected paraleel over the loudspeakeroutputs?
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn. |
#2 |
Just put your multimeter across the two output wires. Start on a high voltage setting on the MM then lower it until you see a reading.
No Source needed. Volume doesn't matter so much but it will vary with different volume setting. Some discussion about what is normal in this thread I started here: DC offset problem and a good page that covered your questions here: http://www.decdun.fsnet.co.uk/gaincloneFAQ.html
#3 |
This is how I did it (mind you, this is my first GC - I'm no expert)
I didn't connect a source. Volume turned up to the max - actually I don't have a volume control, so it's at max by default ![]() Meter first at max dc volts, measure at output. Reduce it step by step till you hit millivolts. Some people put a 10 ohm 5W resistor as the load and measure across this resistor. I didn't. I tried measuring with a sacrificial-goat-speaker connected as load and didn't find any difference. got 70mV with and without load. I guess output impedance of the GC is low enough that the load doesn't make a big difference. |
| gainclone OFFSET regulation LS output | sigurd | Chip Amps | 2 | 21st July 2009 09:23 AM |
| Gainclone with 16vdc offset | roots600rr | Chip Amps | 4 | 27th October 2008 06:48 PM |
| Gainclone with DC-offset problems | seve | Chip Amps | 11 | 28th May 2004 11:01 PM |
| Hissing + DC offset of Bridge-Parallel GainClone | overmind | Chip Amps | 40 | 9th September 2003 05:26 AM |
| gainclone problems (dc offset, no sound) | damitamit | Chip Amps | 3 | 6th September 2003 05:24 AM |
| Page generated in 0.07468 seconds (71.19% PHP - 28.81% MySQL) with 10 queries |
