Old 24th September 2004, 01:51 AM   #21
Originally posted by samsagaz
someone have an one side pcb for lm4870, lm3886 or lm3875?
The one above is an LM3886 one side pcb design.
Except for the LM4780, which is more tricky, you can adapt any double side pcb design for 3886 and 3875 and converti into single side. Parts are just a few.
Follow what Kostas changed since his first design to see how it's done.
Carlos
Old 24th September 2004, 01:55 AM   #22
cjd is offline cjd  United States
For the LM3875...
I have LM3886 layouts as well, just not handy.
C
Old 24th September 2004, 02:10 AM   #23
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Check those: http://www.diyaudio.com/forums/searc...der=descending
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th September 2004, 02:15 AM   #24
peter, ur link dont work, please just put the string that i need to search
cjd, thanks, ill try that.
carlmart, thanks for the tip.
Old 24th September 2004, 02:29 AM   #25
Boardman's LM4780 PCBs (merged)
www.audiosector.com
Old 24th September 2004, 02:57 AM   #26
thanks peter
Old 24th September 2004, 03:29 AM   #27
cjd
have u the schematic for that pcb?
Old 24th September 2004, 08:53 AM   #28
oK guys we are ready :-)
here is the final pcb bottom layer
the dimension are 5x8cm exactly...
thank you carlos, thank you all!
Old 24th September 2004, 10:44 AM   #29
kostas, u tested it?
Old 24th September 2004, 09:37 PM   #30
cjd
It's all in the datasheet... ROut is optional (useful if you try to parallel these).
C
Improved/simplified X-100???? Circlomanen Pass Labs 26 20th April 2007 03:20 PM
Is LM4732 simplified version of LM4780? ozonek Chip Amps 8 28th June 2006 09:19 AM
Simplified LM3886 amp pcb "organic" style Groundloops Chip Amps 0 23rd May 2006 02:46 PM
Simplified FLH's? leadbelly Full Range 8 7th February 2006 08:53 AM
Page generated in 0.09535 seconds (74.87% PHP - 25.13% MySQL) with 11 queries
