Old 22nd September 2004, 07:52 PM   #1
Default Regulated PS Kit
I'm thinking of trying some bi-amping with my Gainclones and an active crossover. I've settled on the crossover, but not the power supply. I've been doing some searching and haven't stumbled upon a simple solution. I'd like to find a +15v -15V regulated power supply PCB, or kit, that somebody has prototyped and procured a few of, similar to what Brian has put together for the LM3875 gainclones. I've seen a few designs, and I guess I could point-to-point something, but if there are PCBs, or kits, available in the U.S. market that would do the job, that sure would be easier.
Old 23rd September 2004, 01:35 AM   #2
thomas997's Avatar
You might want to raise the voltage if possible (20-30)
Although 15 should work alright.
Old 23rd September 2004, 01:59 AM   #3
orpheus is offline orpheus  United States
Default Try Hagerman Bugle Power supply kit.
Jim Hagerman has a 15 + 15 - kit that he sells for his Bugle Phono Preamp. You can adjust the voltage if you want more or less than 15 volts.
I've built one, but I haven't drilled the holes for the chassis yet (my least favorite part of building), so I haven't tried it out yet. Hagerman has a forum at Audiocircle, and he is very quick to respond or help with parts substitutions.
The board is $25, and the parts are all available from Digi-key.
http://www.hagtech.com/bugle.html#powersupply
-Aaron.
Old 23rd September 2004, 02:58 PM   #4
Thanks Aaron. That seems to be what I'm looking for to power the crossover.
Old 23rd September 2004, 07:17 PM   #5
check out circuitspecialists.com
http://www.circuitspecialists.com/level.itml/icOid/4078
kit 124 and 125 work well. I used them in a preamp last year. No problem yet! All you have to do is supply the appropriate xformer.
Greg
Old 23rd September 2004, 07:31 PM   #6
Great! Thanks Greg.
Now I've got Hagerman using the NJM78M15FA & 79M15FA chips, Circuit Specialists using the LM317 & 337 chips and Marchand using the LM340 & 320 chips.
Old 24th September 2004, 12:23 AM   #7
ofb is offline ofb
another option for small simple +-15 using 317/337 is on this page. no pcb, but it goes together quickly on perf board. you can get all the parts from digikey.
http://headwize.com/projects/showfil...stokes_prj.htm
add small heat sinks to the parts lists. doesn't need anything fancy. i'm using it in a meta42 and it barely gets warm.
Old 24th September 2004, 03:20 AM   #8
thomas997's Avatar
sorry was thinking about the wrong thing, ignore my post.
Regulated PSU?? MikeFarad Solid State 4 12th July 2007 10:41 PM
Regulated or non-regulated SMPS longitude Class D 5 8th May 2007 03:02 PM
Need a little help with my first regulated PSU jarros Power Supplies 16 2nd May 2005 11:28 PM
Regulated PSU Help.. jleaman Analogue Source 9 26th July 2004 12:36 PM
Regulated or no regulated PSU? Higo Chip Amps 2 16th July 2003 04:38 PM
Page generated in 0.11095 seconds (68.57% PHP - 31.43% MySQL) with 10 queries
