Gainclone in a Hammond 1455 case
Old 21st September 2004, 08:32 PM   #1
hifi is offline hifi  Sweden
Default Gainclone in a Hammond 1455 case
the case is 103x53x160
/ Mikael
Old 21st September 2004, 08:33 PM   #2
and an internal one
/ Mikael
Old 21st September 2004, 08:53 PM   #3
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Very nice from the outside Mikael but Mr Flibble seems to have lost the interior shot!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 21st September 2004, 09:08 PM   #4
second attempt
Old 21st September 2004, 09:17 PM   #5
troystg is offline troystg  United States
troystg's Avatar
Hey Mr. Fibble-
Very nice.
How'd you fit that torid in that case!! Must have slid it in from the end...
Thanks,
Troy
Old 21st September 2004, 09:20 PM   #6
You are right. It along with the copper bar is mounted on a 2mm alu plate. And do notice there are no holes on either side of the case. : o)
/ Mikael
Old 21st September 2004, 09:39 PM   #7
troystg's Avatar
Mr. Flibble-
I just "assumed" you had bolts sticking out the other side.
I see now... You used the PCB slots for the 2mm Alum. and that is what holds everything in place.
OUT STANDING! Really nice and elegant design.
I may do something similar for friends who request a GC.
Thanks,
Troy
Old 21st September 2004, 11:53 PM   #8
cancerkazoo is offline cancerkazoo  United States
Nice. I was looking at that case a couple of days ago, nice and small. What size is that transformer? Is that your own board design? If so could you post something for us to print to etch our own boards with?
Steve
Old 22nd September 2004, 01:22 AM   #9
Its only a 80VA transformer although there is room to fit a 120VA.
If you can mannage to bend the bottom (the slide in bottom) in an U shape or accept a bolt trough one side.
The toroid is wound to have 2x18V windings wich gives about ~35W of outputpower so I got more than twice the amplifiers rated yield and I feel pretty comfortable with that.
The board are the same as those availible from BrianGT although I used 1000uF/50V Elna Silmics instead of the FC:s
/Mikael
Old 22nd September 2004, 08:29 AM   #10
Nuuk's Avatar
Before the days of DIY hi-fi, men used to put ships in bottles to pass their time away. Now Mr Fribble has brought the two hobbies together!
Yes, very well executed. I would not have thought that an amp and its PSU could go in that tiny case!
It cuts the cost of using two cases, extra sockets and an umbilical cable!
Gainclone in a Hammond 1455 caseHide this!Advertise here!
FS: Hammond Enclosures davidhs Swap Meet 2 18th April 2007 03:52 PM
another case of gainclone hum adolphe Chip Amps 11 9th May 2006 02:54 AM
Plastic End Panels for Hammond Case orthoefer Swap Meet 0 9th May 2006 02:19 AM
Hammond Transformers Gabevee Tubes / Valves 0 5th April 2004 02:47 PM
CMoy In Hammond 1455 Case Lil_JV Chip Amps 0 6th September 2003 09:43 PM
