| Chip Amps Amplifiers based on integrated circuits |
#31 | |||
Banned
Let it If you don't want do make an inverting amp (with buffer, preferably), with NI this is the way to go IMHO. What's debatable is what has more effect to the sound? - 80mv DC or - Ci caps? Your speakers may not work so well with 80mv DC. But the effect of the Ci caps, if they are decent quality, is minimal if not undetectable. |
#32 | |
One last Q though, I have used a cheap generic cap that is 35V, cost 50c. The only place I can get better ones in NZ is RS so do you think Elna Starget (for example) caps would be worth paying $10-$15 for? or shall I just use generic low ESR ones? |
#33 | |
Like I said on another thread, according to an article published in Electronics World and Wireless World, try a bipolar capacitor as feedback DC block. Something reasonable good, not any speaker cap you may find around. If the feedback resistors you are using are large, particularly the small one, you can even get to use film caps. Something like 2 x 4.7uF should not be expensive to arrange. Carlos |
#34 |
I am having dc offset problems as well (about 60mV on both outputs). I don't have any .22 uF caps on hand but I do have some 0.1uF caps on hand ( http://www.partsexpress.com/pe/showd...number=027-452 )
Can I use these for Ci? My gainclone is exactly like noninverting "classic" circuit at http://www.geocities.com/rjm003.geo/...io/diy_gc.html excpet I don't have R5 and C5 on the outputs. Thanks. |
#35 |
I would say 60mv is pretty ok...you might wanna test them out with a junk speaker 1st though
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#36 |
diyAudio Moderator Emeritus
I have one channel ~70mv and the other ~130mv. No problems with it.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#37 |
maxw,
Did you take offset measurements with the input conected? Because if input is connected to a source, your readings might change again. Same goes for heat, aging effect.. etc. Dont worry too much about offset, especially if its low like in your case. It will change again after sometime. I (and many others?) personally disgust of having Ci there in the circuit. What I would suggest is to try as many chips as you could to find a low-offset pair.(like what gaincard guys did?) |
#38 | |
Im sure this problem will crop up again with my LM3886 and LM4780 amps but I wont be so concerned this time Im glad someone else found this thread usefull too. |
#39 |
Why all these worries about dc offset?
I build a gainclone, two channels, without Ci, and it have 110mv in one channel and 90mv in the other... When I power it on, I don't listen anything, and it do not move the driver surface... Forget it and be happy !
| offset problem | intense-tavda | Solid State | 6 | 22nd June 2009 08:24 AM |
| DC offset problem | mravlcax | Chip Amps | 21 | 30th April 2008 10:08 AM |
| Another Offset problem... | rtate | Solid State | 6 | 19th March 2008 11:03 AM |
| A40 offset problem? | stickleda | Pass Labs | 8 | 1st May 2005 12:56 AM |
| Is this DC offset problem. | rs1026 | Chip Amps | 4 | 24th December 2004 12:02 AM |
| Page generated in 0.11119 seconds (83.98% PHP - 16.02% MySQL) with 11 queries |
