| Chip Amps Amplifiers based on integrated circuits |
Hello,
I'm trying to assembly BrianGT's/Peter Daniel's kit as a first project. I've managed to get everything assembled correctly up to soldering the nfb resistor to pins 3 and 8. During the course of solder pin 8 the clamp slipped and the resistor lead now also touches pin 9. According to the National spec sheet, pin 9 appears to be NC. Should I try and unsolder the resistor and try again or is it safe to leave it as is? My searches here dug up a debate of whether NC means not connected or do not connect... ( I hope spending 30 mins searching through threads is sufficent). A quick thank you to Peter Daniels and BrianGT for their patience in answering my questions about the kit. regards Dave |
#2 |
If you look at data sheet it pin 9 is No Connection further you will note that the board itself has no metal to the hole for pin9
So no problem in any way
Sheldon D |
#3 |
NC means not connected. No problem.
Franz |
#4 |
To clarify, I soldered the resistor directly to the chip so pins 8 and 9 are shorted. It's been many years since high school electronics so I'm rather insecure about my interpretations of the spec sheet.
I probably wouldn't have posted but one thread mentioned someone connecting all the nc pins of a not chip amp circuit to ground and promptly blew up the chip. ![]() Thanks for the replies. Dave |
#5 |
Really, dont worry!
I did not look at the datasheet or pin numbers. But: if you connected a NC pin to another pin: NO PROBLEM! But: maybe your soldering iron is too big? Or you could easily remove the problem. Don't you think? Really. Franz |
| A klutz needs a bit of help | polkat | Car Audio | 5 | 22nd July 2006 08:51 PM |
| BrianGT's 4780NIGC assembly & comment | digi01 | Chip Amps | 12 | 2nd February 2005 12:01 AM |
| The big assembly question! | NUTTTR | Solid State | 7 | 22nd January 2005 03:36 AM |
| Simple toroidal power supply assembly question | wigginjs | Solid State | 0 | 2nd July 2004 05:41 PM |
| BOSOZ assembly question | moe29 | Pass Labs | 3 | 9th February 2003 09:07 PM |
| Page generated in 0.08592 seconds (73.53% PHP - 26.47% MySQL) with 10 queries |
