Ready to build my Gainclone
Old 17th September 2004, 10:05 AM   #11
ebijma is offline ebijma  Netherlands
ebijma's Avatar
Originally posted by Nuuk
So, if you have +/-35 volt rails before the regulators, you could regulate down to +/-27 volts, still leaving enough headroom as described above by Pedja.
But if you are having your transformer built, why not specifiy 27 VAC secondaries (although this will be a bit high if for any reason you decide not to stick with the regulated supply later)?
Thanks Nuuk,
Transformer with +/- 27 volts is an good idea.
This gives me about +/- 38 volts than regulated this to 30 +/- volts.
Originally posted by carlosfm
One thing is using what you have.
But if I was going to order a custom-made trafo for using at +/-30v with LM338s, I would order 2*27v.
The ideal situation is between 5 and 10v voltage drop.
Point to the middle, that should be fine.
Thanks Carlosfm,
Good idea.
But can i use one lm338 for the positive and one for the negative rail and connect both channels?
So what regulator is the best?
I have two lm338 but if the lt1083/84 are better i would rather order these.
I think i will stick with the lm338 for now.
Music is what i want, music is what i need
Old 17th September 2004, 11:53 AM   #12
carlosfm is offline carlosfm  Portugal
Banned
You can use a pair for both channels, it works fine.
I haven't tried the LT1083.
Old 17th September 2004, 12:38 PM   #13
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
ebijma - you will gain a lot from reading the previous threads on regulated supplies for GC's (on this forum).
We talked about things like adequate heatsinking, use of LM338T compared to LM338K and most of the other issues that you will need to know.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 17th September 2004, 01:17 PM   #14
ebijma's Avatar
Hello Nuuk,
I know i've bin reading allot about it on this forum.
But my questions still remained.
So i placed a thread of my own.
My question wasn't about heatsinking and not about the use of LM338T or the LM338K.
But thanks anyway.
Old 17th September 2004, 08:23 PM   #15
yldouright is offline yldouright
Banned
Send a message via AIM to yldouright Send a message via Yahoo to yldouright
ebijima
I would like to know how you built the phono preamp for your gainclone? I am thinking about integrating a phono section into a gainclone and running the whole thing in an old Kenwood amp case. Are you putting the phono stage in a separate case?
Old 18th September 2004, 04:49 AM   #16
ebijma's Avatar
Originally posted by yldouright
ebijima
Hello yldouright,
The phone pre is not specialy for the gainclone.
I build it in a separate housing.
Read all about it here....
http://www.diyaudio.com/forums/showt...threadid=33555
Its a simple but very good sounding pre.
Old 18th September 2004, 12:05 PM   #17
Banned
ebijma
The link "has exceeded its bandwidth" but I will check it again. In the meantime, why did you decide to build it in a separate case instead of making it a stage within a larger gainclone? From reading Kuei Yang Wang and others, it seems that the shorter the signal paths the better so I am assuming that integrating the phono stage would have resulted in better sound. Was this a power supply issue?
Old 18th September 2004, 03:21 PM   #18
ebijma's Avatar
ebijma
Hello yldouright,
I build mine for use in the living room, i have a jvc set there and i wanted to connect a turntable to it.
The gainclone im going to use in a other room.
Thats a kind of listing room.
In the future im going to build another phono pre and a non oversampling DA converter for use in my listing room.
Old 18th September 2004, 03:48 PM   #19
Banned
ebijma
Understood. Which DAC are you looking at to use with the Gainclone?
Old 18th September 2004, 03:56 PM   #20
ebijma's Avatar
ebijma
Im planning on building the DDDAC 1543.
Its on this website.
http://www.dddac.de/
Then klick on the NEW !! DDDAC 1543 button.
Ready to build my GaincloneHide this!Advertise here!
i am ready to build Aleph-X space2000 Pass Labs 26 14th July 2008 02:34 AM
I'm ready to GAINCLONE!!!! davidlzimmer Chip Amps 22 5th May 2006 11:47 PM
Ready to build ZV9 - Need heatsinks! Paul Ebert Pass Labs 15 29th April 2006 08:38 AM
Ready to build! hawkfeather Solid State 2 10th February 2006 05:05 AM
Copyright ©1999-2017 diyAudio
