| Chip Amps Amplifiers based on integrated circuits |
Hi All,
I'm looking at a headphone amplifier kit which uses an LM386 as the chipamp. Could anyone suggest a better quality amp that could be swapped in the same circuit? For reference, the circuit is shown in this document: http://www.ramseyelectronics.com/dow...nuals/SHA1.pdf Thanks! |
#2 | |
Why did you choose that project? If it's for sound quality, something like the buffer combo we usually talk about here, with OPA627 + BUF637, will sound a lot better than this circuit. Carlos |
#3 |
I'd recommend looking at Tangent's mint or pimeta boards.
http://www.tangentsoft.net/audio/mint http://www.tangentsoft.net/audio/pimeta Both of these are reasonably low cost and fairly high-end compared to the "single op-amp" based headphone amplifiers. I don't have any association with tangent other than having bought his products and being a satisfied customer. |
#4 | |
Thanks! This is exactly what I'm looking for. I did find another kit, but it's probably overkill: http://www.audiokits.com/products.asp?prodid=395 Thoughts? |
#5 |
The LM386 isn't an easily swappable chip. It has the gain internally set and the pinout isn't "standard". You won't be able to drop in a replacement directly without changing the circuit.
#6 | |
Tangent's or Audiokits' are probably the way you should go for serious headphone amps. Carlos |
#7 |
Believe nothing you read and only half of what you see. |
#8 | |
I agree. You can build quite a few different types of amps from there. If you're sure you want to go with an op-amp based headphone amplifier, check out the "chu moy" .. You can probably build one for less than $20, including the enclosure (the ever popular altoid mint tins). |
#9 |
Í build a headphone-amp with OPA2134's (from www.raymondaudio.nl. Project 7.
Amazing sinpele and good !!!! For what i reed about it is the OPA 2134 better than the one you intent to use. succes
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn. |
| Lm386 | frenchie29 | Chip Amps | 10 | 27th April 2009 09:32 PM |
| Need some help with DAC and LM386 | zhane | Chip Amps | 6 | 21st April 2008 07:38 PM |
| filtering before LM386? | newsci | Chip Amps | 7 | 26th March 2008 09:18 AM |
| lm386 poweramp | prorms | Solid State | 4 | 23rd May 2006 07:50 AM |
| LM386 but on AC? | tubbytwo | Chip Amps | 6 | 29th November 2004 12:38 AM |
| Page generated in 0.09955 seconds (79.56% PHP - 20.44% MySQL) with 10 queries |
